h2b turbo blows tires in 5th gear wtf......@ only 9.4 lbs of boost........
Old Oct 25, 2008 | 10:11 AM
rev-speed's Avatar
Default h2b turbo blows tires in 5th gear wtf......@ only 9.4 lbs of boost........
setup
head
-bone stock
-no upgrade valve train no porting
-stock cams
block
-mahle pistons
-eagle rods
-acl bearings
turbo setup
-ebay kit with t3/t4 .57 trim
-daily driven on open downpipe
fuel management
-1200cc rc
-stock fuel rail
-stock fuel pressure regulator
-stock fuel filter
-walbro 255lph fuel pump
-hondata s200b
tires
-kumho v10
On 91 octane the car blows 1st through 4th gear if the tires need heated up
once s it heated up u can get traction in 4th
this is with 91 octane pump gas with only 9.4lbs of boost...........
On methanol it blows tires on 5th gear at around 3700 rpm
thats 5th gear punching it at 2500 rpm
datalog shows 9.4 psi at 3300 rpm!
this is still with 9.4lbs of boost and same v10 tires (18 psi tire pressure)
What should we do?
we want to street tune the car before going to dyno....
Old Oct 25, 2008 | 10:18 AM
mrbigg9032's Avatar
Are you sure your clutch isn't slipping???
Old Oct 25, 2008 | 10:19 AM
locash's Avatar
Default Re: h2b turbo blows tires in 5th gear wtf......@ only 9.4 lbs of boost........ (rev-speed)
Tune the car on the dyno, before you kill yourself or someone else.
It makes more sense to do the dyno tuning first. Part throttle tuning on the street is one thing, but WOT is just foolish.
Old Oct 25, 2008 | 10:41 AM
Schister66's Avatar
Man U FTW
Default Re: (mrbigg9032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure your clutch isn't slipping???</TD></TR></TABLE>
That was my initial thought as well. I REALLY doubt you're spinning in 5th gear...
Old Oct 25, 2008 | 10:45 AM
mrbigg9032's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
That was my initial thought as well. I REALLY doubt you're spinning in 5th gear...</TD></TR></TABLE>
Exactly I mean how much power could it possibley be making UNTUNED maybe 300whp..
Old Oct 25, 2008 | 11:23 AM
LastGenEK's Avatar
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">. I feel like a ricer for even reading the thread </TD></TR></TABLE>
Old Oct 25, 2008 | 01:14 PM
rev-speed's Avatar
no not a clutch problem
we will make a video
Old Oct 25, 2008 | 01:17 PM
rev-speed's Avatar
Exactly I mean how much power could it possibley be making UNTUNED maybe 300whp..</TD></TR></TABLE>
it has to be around 400whp
on 91 octane it blows the tires in 4th unless tires are warmed up.........
Old Oct 25, 2008 | 01:20 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I'd also look into your alignment and suspension setup lol
But something still wouldn't be right. I feel like a ricer for even reading the thread </TD></TR></TABLE>
wait till you see our vid of the 400whp car
on 91 octane 9.5lbs of boost through the muffler
Old Oct 25, 2008 | 03:03 PM
gsrious's Avatar
so what size tire is seng using when you are tuning his car tom?
either the tires are really old(hard) and full of pressure...
or
you should tell seng to put on some soft drag tires, then go on from there.
Modified by gsrious at 4:10 PM 10/25/2008
Modified by gsrious at 4:33 PM 10/25/2008
Old Oct 25, 2008 | 03:11 PM
hyabusa hunter's Avatar
Default Re: (gsrious)
also, are the V10 drag tires, from what ive read they are not
Old Oct 25, 2008 | 03:26 PM
gsrious's Avatar
Default Re: (hyabusa hunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">also, are the V10 drag tires, from what ive read they are not</TD></TR></TABLE>they are road racing tires(stiff sidewalls), which = failure to deliver in drag.
Old Oct 25, 2008 | 04:07 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">so what size tire is seng using when you are tuning his car tom?
or
Modified by gsrious at 4:33 PM 10/25/2008</TD></TR></TABLE>
the cars not seng s
seng's is tuned by church
his grabs in third gear
Old Oct 25, 2008 | 05:41 PM
96 GSR-T's Avatar
a .57 trim roasting 5th gear under 4krpm/10lb boost? Are you on ice? Your running Methanol through your Walbro 255?
Old Oct 25, 2008 | 05:54 PM
marcj's Avatar
Default Re: (96 GSR-T)
A.) slipping clutch
B.) shitty suspension
C.) shitty tires
D.) B & C
E.) all of the above
Old Oct 25, 2008 | 07:05 PM
ecks_fourttwo's Avatar
its my car, and i can vouche for the roasted tires... why is everyone so doubtfull? oh yeah, all of honda-tech members are experts at everything auto related!
Old Oct 25, 2008 | 07:06 PM
the v10's are the best "street" slick that ive ever used... so many people doubt then until they get a feel of em in action...
Old Oct 25, 2008 | 07:21 PM
96 GSR-T's Avatar
Default Re: (ecks_fourttwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecks_fourttwo &raquo;</TD></TR><TR><TD CLASS="quote">its my car, and i can vouche for the roasted tires... why is everyone so doubtfull? oh yeah, all of honda-tech members are experts at everything auto related!</TD></TR></TABLE>
lol, we are doubtful because a .57 trim at 10psi is not a 5th gear tire roasting snail, I cant roast 5th gear in my car at almost 600whp.
Whats this talk about Methanol, are you running straight Methanol or spraying it?
Old Oct 25, 2008 | 07:26 PM
straight methanol.
Old Oct 25, 2008 | 07:33 PM
sa90eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecks_fourttwo &raquo;</TD></TR><TR><TD CLASS="quote">straight methanol.</TD></TR></TABLE>
are you sure its not soysauce
Old Oct 25, 2008 | 07:48 PM
pheurton-skeurto's Avatar
Default Re: (sa90eg)
this thread is a huge waste of bandwidth.
Old Oct 25, 2008 | 08:09 PM
andoxviii's Avatar
Default Re: (marcj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcj &raquo;</TD></TR><TR><TD CLASS="quote">A.) slipping clutch
C.) shitty tires
D.) B & C
E.) all of the above</TD></TR></TABLE>
haha
"...and remember children, make sure you are using your HB pencils!"
Old Oct 25, 2008 | 08:33 PM
96 GSR-T's Avatar
So your flowing straight Methanol through your stock tank, a walbro 255 which then makes its way through stock lines into a stock rail and out a stock regulator.... wow if it were really that easy we would all run Methanol.....
Since Meth pretty much requires double the amount when compared to gasoline, if you were in the 400whp range on Meth your magical Meth compatible Walbro 255 is flowing enough for 800whp on gasoline with stock lines etc, not to mention I dont think RC 1200's would even be enough for 400whp on Meth even if the single 255 could get you there, interesting.......
Modified by 96 GSR-T at 12:42 AM 10/26/2008
Old Oct 25, 2008 | 11:24 PM
sa90eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by 96 GSR-T at 12:42 AM 10/26/2008</TD></TR></TABLE>
tom at rev-speed made over 400whp on 1000cc injectors and a bad cylinder on meth on their 2.0 motor setup... there are some key words in your post that stand out, and i think it says it all....
Old Oct 25, 2008 | 11:25 PM
sa90eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa90eg &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure its not soysauce </TD></TR></TABLE>
hahahahahahahaha
