need a suggestion....
Old Oct 25, 2008 | 07:21 AM
cjmurillo's Avatar
Default need a suggestion....
ok so i have lots of parts laying around....h22 head, h23 head, f23 block, f22 motor....was wondering what etup would e better....f23 block with which head?....h22 or h23?.....was thinking of going with the h23 head for the high compression since im on the bottle and people say its good with high compression but any opinions are welcome thanks....
Old Oct 25, 2008 | 12:32 PM
P_Adams's Avatar
Default Re: need a suggestion.... (cjmurillo)
It all comes down to the reliablity issue.
High compression is a traditional route for All-Motor applications.
Low compression is more the rhelm of boost (either turbo-mechanical or gassious) all because of one controlling factor: metalergy.
High compression combined with a cast aluminum piston (and the "bottle") will get you one thing:
A Paper Weight.
Take your time, do your research and do the job once. The results will be far more rewarding.
P
Old Oct 26, 2008 | 04:12 AM
jwicecold's Avatar
Yea defiantly do a lil more research on the subject but I heard from another honda mechanic that an f23 with h22 or h23 head would be a great setup!!!
But then it comes down to NA or forced induction... Which are you trying to build??
Old Oct 27, 2008 | 08:04 AM
cjmurillo's Avatar
trying to put something together that i can put nitrous with....
Old Oct 27, 2008 | 10:40 AM
P_Adams's Avatar
Default Re: (cjmurillo)
Well... a bone stock motor will tolerate Nitrous (at moderate levels) for a bit, but ultimately you're going to break something; particularly if it's coupled with high compression (9:1 or higher).
Anything over 100hp (consistantly) should require some attention to stronger Pistons, Connecting Rods and better Bearings.
And pay particular attention to at what RPM you hit the switch.
I've seen more than my fair share of engines "grenade" from applying it too soon.
P
Old Oct 27, 2008 | 10:47 AM
cjmurillo's Avatar
so what do you think about using the f23 block with the h22 head and just keeping the stock f23 pistons.....
Old Oct 27, 2008 | 01:11 PM
Brad_and_the_acc's Avatar
The H22 head with the F23 block would be a good choice for a low comp setup. Quite a bit of work from what I have seen and understand.
Be a little bit more descriptive on what exactly you are trying to do with your "G" series thoughts and we can help you more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjmurillo &raquo;</TD></TR><TR><TD CLASS="quote">trying to put something together that i can put nitrous with....</TD></TR></TABLE>
This doesnt help AT ALL. Anyone can throw on a bottle and blow up ANY motor, Takes research and trial and error to be reliable.
Old Oct 27, 2008 | 01:31 PM
cjmurillo's Avatar
sorry.....i guess my question would be what would be better to run the nitrous with....high or lower compression
Old Oct 27, 2008 | 05:53 PM
P_Adams's Avatar
Low compression - squirt away
High(er) compression - I'd be VERY conservative and work your way into it.
P
Old Oct 28, 2008 | 01:02 AM
jwicecold's Avatar
Honestly though nitrous is no good for your car... Are you dragging it??
Old Oct 28, 2008 | 07:09 AM
cjmurillo's Avatar
what do you mean am i dragging it? as in using it for drag racing only?
Zohaib Ali
Apr 6, 2017 05:47 AM
robertbaisley
Mar 6, 2012 03:29 AM
tarheelsoldier
Feb 26, 2006 04:48 PM
VividBlueFit
Sep 8, 2003 06:44 AM
FBTuning
Sep 3, 2003 10:41 AM
