DOHC ZC pg7 ecu help
I have a DOCH ZC in my 91 crx. i just installed the 89 integra ecu a pg7 to give my car a higher rev limit. As soon as i installed it the check engine light came on. Any ideas. Please help
You must have an auto ECU, the 5spd ones are rare and I've had at least 5 different CRX/engine/PG7 combinations and the only time I got CEL's was when it was an auto ECU (or O2 sensor but you'd already have known about that one) when I rocked the DOHC ZC I did use the stock ZC cam sensor with a 6-pin DX Dizzy, if you're using an Si dizzy it might be slightly different, but adjusting the dizzy one way or the other would make the code go away probably.
i was running my dohc zc on a ps9 ecu, 90-91 4dr civic ex auto ecu, for a couple of days.
it was running fine, but had a code 19.
code 19 = Lock up control solenoid (auto trans only).
i got a pg7 ecu off my friend that came off his car, but had that code, so i opened up the ecu casing, and it was a ps9. open yours if its a pg7, then you have an automatic one if your throwing a code 19.
jabiboo
16
Jul 19, 2010 10:29 PM
