need help 93 civic hatch with h22a swap
Old Oct 24, 2008 | 07:18 PM
blake_187's Avatar
Default need help 93 civic hatch with h22a swap
hey well i just got the swap dun and not sure y its acting like this
when i go to start it it turns over for ever then stutters. like wants to start but dosint and i dont wanna burn the starter so i stop and turn it over agin then it starts that time or the next. but when its started it runs ruff hole car shakes and rpms are up and down sounds like it wants to die but dosint .if some 1 could help maybe let me know things i could check or what u think is wrong. and sorry im a newbe at the forms
Old Oct 24, 2008 | 07:33 PM
iamthefollower's Avatar
Default Re: need help 93 civic hatch with h22a swap (blake_187)
hmm, i havn't seen one do this yet, but i'll do some researching and see what I can find out for you.
Old Oct 25, 2008 | 06:39 AM
blake_187's Avatar
Default Re: need help 93 civic hatch with h22a swap (iamthefollower)
hey thank u and do u know if the h22a motor is run on points i herd that might do it or bad timing
Old Oct 25, 2008 | 06:56 AM
rpared01's Avatar
what ecu are you using ? check for any air leaks, timing may be another factor
Old Oct 25, 2008 | 07:21 AM
blake_187's Avatar
Default Re: (rpared01)
im not sure whitch ecu would it say on it ? ill try to take a vid of me starting it and at a idle so ppl can hear it thanks
Old Oct 25, 2008 | 07:22 AM
blake_187's Avatar
and ill check for air leaks
Old Oct 25, 2008 | 07:44 AM
Mr.Chow's Avatar
your timing is off. 90% sure...vacum leaks wouldn't do this.
Old Oct 25, 2008 | 10:42 AM
blake_187's Avatar
Default Re: need help 93 civic hatch with h22a swap (Mr.Chow)
okay do i need a timing light to set it or what
Old Oct 25, 2008 | 10:43 AM
punkinbeck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blake_187 &raquo;</TD></TR><TR><TD CLASS="quote">hey well i just got the swap dun and not sure y its acting like this
when i go to start it it turns over for ever then stutters. like wants to start but dosint and i dont wanna burn the starter so i stop and turn it over agin then it starts that time or the next. but when its started it runs ruff hole car shakes and rpms are up and down sounds like it wants to die but dosint .if some 1 could help maybe let me know things i could check or what u think is wrong. and sorry im a newbe at the forms </TD></TR></TABLE>
http://www.dictionary.com
Old Nov 6, 2008 | 11:07 PM
blake_187's Avatar
is thare a way i can ajust the dizzy to retart it or make it run rich
Old Nov 6, 2008 | 11:12 PM
butter99's Avatar
https://honda-tech.com/zerothread/1901557
checking trouble codes might help..mayb
haven't tried this myself..but sounds fun
djnikko
Jan 12, 2010 02:50 PM
worx
Feb 1, 2008 01:19 PM
H22ARunninHard
15
Jul 26, 2007 03:01 PM
JDMH22-92CB7
Jul 1, 2007 06:50 PM
