new clutch. new problem
installed everything. started up fine.
this is what's happening.
when i press on the clutch pedal all the way down it wont wanna shift. but it will disengage when i depress it less than half way down but kinda engages when i press it down all the way.
other than that the clutch feels fine. any idea?
Sounds like something with the piece of metal that pivots the throwout bearing while the slave cylinder is moving. I'd loosen the slave cylinder, look around, and go from there if you need to pull the tranny.
Check clutch fork and slave cylinder. Did you bleed the slave properly after installing the clutch?
Can't put an axle in too far, but can tear the seal up if you are sloppy when putting the axle in the diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Lightly coat the outside with oil press in with hands until outer edge is flush with case.</TD></TR></TABLE>
really.. just by using hand? no rubber mallet or anything?
From: With my POS D15B2, Whereever whenever, United States
If everything is installed properly it is something wrong with your clutch master or slave cylinder.
Also double check that the fork is seated onto the ball of the trans so it pivots horizontally back and forth correctly when the slave pushed it in and out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">I always get them in by hand. I never use a mallet.</TD></TR></TABLE>
X2
X2
i never oil the outside, as if it's easy to go in, it'll come out easy, which is bad, mmmkay? so i leave the outside dry, put wheel bearing grease on the axle race (the part of the seal that the axle rides in), and press it in as far as i can with my fingers, then tap it in around the edges with a hammer.
after it's in place, pay attention to the end of the axle that is to be inserted into the tranny. theres a small C-clip in a groove in the very end. make sure the opening of this clip is straight down when inserting, so nothing catches the diff seal. you should be able to see what i'm talkin about when you look at it/think about it
just know it's common for people to screw up/rip the axle seal if they aren't paying attention.
good luck
good luck
vi3tromanc3r
Mar 9, 2007 12:56 PM
unidextrous
Jan 11, 2003 02:48 AM
