JDM B18C Distributor Cap and Rotor
Old Oct 24, 2008 | 02:20 PM
CTR-GSR's Avatar
Default JDM B18C Distributor Cap and Rotor
Is it different from the USDM version? Thanks!
Old Oct 24, 2008 | 02:27 PM
BlueIntegraBoy's Avatar
Default Re: JDM B18C Distributor Cap and Rotor (CTR-GSR)
no
Old Nov 10, 2012 | 07:07 PM
huxtable's Avatar
Originally Posted by BlueIntegraBoy
no
Edit nevermind, the teeth part got stuck to the shaft blocking the hole.
Old Nov 10, 2012 | 08:26 PM
Hybrid96EK's Avatar
Perhaps it's not an oem unit you have then? I've seen some remans that have the press on style rotor before. I don't think this is enough info to get all pissy about it and tell someone they are WRONG.
Old Nov 10, 2012 | 09:40 PM
Todd00's Avatar
I said I don't want a title!
Did I stumble into the JDM ITR parts forum again? Must have mis-clicked.
Old Nov 11, 2012 | 07:58 AM
JDM CTR '00's Avatar
The JDM/USDM Distributor is the same. I just replaced the cap and rotor in both my CTR B16b & JDM ITR B18c using USDM ITR cap and rotor.
Old Nov 13, 2012 | 01:37 PM
huxtable's Avatar
This is correct, part of my rotor got stuck to the shaft and I thought it was different...woops.
Old Nov 18, 2012 | 07:54 AM
S2kRyan's Avatar
The OP has a throw away unit that all the local parts stores are selling these days. They do not come with a replaceable rotor button and come with a no name cap pre-installed. OEM has the TD-86 stamped into the cam tower leg of the distributor. All of the aftermarket throw away units have a sticker TD-84u.
skata89
Dec 22, 2007 08:53 PM
whatcivic
Nov 8, 2007 11:30 AM
builthatch
Apr 18, 2007 09:46 AM
tunedek
Apr 14, 2007 03:03 PM
psegs80
Feb 4, 2006 07:35 PM
