BUDDY CLUB SUPER SUPER DUPER DUPER SALE!
Please PM me, AIM me at <FONT COLOR="orange">VelocityTrends1</FONT>, email me at noah@velocitytrends.com, or call me at the shop at <FONT COLOR="GREEN">904.997.9903</FONT> for the HONDA-TECH PRICE! Ask for the <FONT COLOR="RED">NEWEST PROMO CODE</FONT>!
We are now offering a sale on all Buddy Club suspension products!
The first option is the <FONT COLOR="blue">N+ Spec Dampers</FONT>!
"N+ SPEC DAMPER" from Buddy Club is the choice complete suspension setup with resemblance of our RACING SPEC damper's excellent attributes. It is cost effective and is well rounded for the budget minded weekend club racer. With optional urethane isolated aluminum upper mount design, engineered spring rates, 15 level damper adjustability, and ride height adjustment capabilities, the N+ SPEC DAMPER can accommodate any driver's preferences.
They offer:
1. Ride-Height Adjustable
2. 15 Level Adjustment
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Mono-Tube Type Shell Case
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
4. Great Quality Finish
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
They are available for the following vehicles:
<u>Acura</u>
Integra (DC2, Type R)
TSX
RSX (DC5)
<u>Honda</u>
S2000
Civic Si (EP3)
Civic (EG6)
Civic (EK9)
For the Integra (DC2, Type R), Civic (EG6), and Civic (EK9) upper mounts are an available option for an additional amount.
The second option is the <FONT COLOR="blue">Racing Spec Dampers</FONT>!
"Racing Spec Damper" is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests
They offer:
1. Adjustment Bracket
With an adoption of a "adjustable bracket" the ideal low postion can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
The 15 level adjustment corresponds to variety of racing stages, from Touge 'mountain roads' to cicuits. Adjustment is easy with its click adjusting dial. The dial is located ither on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Single Tube Type Shell Case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissapation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
4. Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chasis movement. Caster adjusment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
5. Spring Seat / Lock Seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
<u>Acura</u>
NSX (NA1/2)
TSX
RSX (DC5)
<u>Honda</u>
Accord (CF4)
Civic (EF9)
Civic (EG6)
Civic (EK4/9)
Civic (EP3)
CR-X (EF8)
Prelude (BB1/4)
S200 (AP1/2)
For the Integra (DC2, Type R), Civic (EG6), Civic (EK9), and S2000 (AP1/2) upper mounts are an available option for an additional amount.
Don't forget, whenever lowering a vehicle it is recommended to run a camber kit. Luckily Buddy Club offers their own so we can put together a combo package for you!
The Buddy Club camber kits is a little different from all the other camber kits available. By using low profile joints they offer 5mm more clearance between the top of the kit and the bottom of the strut tower.
The <FONT COLOR="blue">P1-Racing Camber Kit</FONT> is available for the following vehicles.
<u>Acura</u>
<u>Honda</u>
Civic (EG6)
Civic (EK9)
Modified by velocitytrends at 5:21 PM 10/24/2008
velocitytrends
109
Feb 15, 2010 06:34 PM
passwordjdm
16
Aug 1, 2005 11:30 AM
