Ram horn or Top mount for a DD???
ok,
i have a 81.5mm b16 that i am building and i plan on pushing 400-500whp, while daily driving this bad boy, what do you guys reccomend for a manifold a ram horn or top mount? turbo is a garrett t3/60-1 .63ar turbine, and the turbo kit will be AFI.
At this point, its not going to matter too much. You could easily use a ramhorn and have great success with it. It really comes down to the design of the manifold. The ram will flow more than enough for your goals, but it has shorter runners which will cut spool time down a bit. The topmount makes for easy turbocharger maintenance and generally better overall flow (top end), but since the runners are a longer, it will increase the amount of lag. I have a good comparison between a mini-ram and topmount if you're interested in seeing that for a reference...
i have a topmount on my stock b16 with tha same turbo except for my exhaust houseing is .82.. i love it.. it is a bit laggy 5500 full boost.. but when u spin to 9k its all good..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">... I have a good comparison between a mini-ram and topmount if you're interested in seeing that for a reference...</TD></TR></TABLE>
id like to see for fun
turbosnail1000
Feb 4, 2011 10:28 AM
