gsr help
Old Oct 23, 2008 | 10:11 PM
sd_ej1's Avatar
Default gsr help
the engine wont start i need help !!!
everything is working fine and it sound like its about to start
but it just wont start.
i dont know how to put that but hopefully that described my situation
oh btw i let my cousin drive, he stalled alot. did that have something to do with it ?!
HELP !!!
Old Oct 23, 2008 | 11:15 PM
99SlammedCivic's Avatar
Snipper Snapper
Default Re: gsr help (sd_ej1)
Did he go off and unplug something ? If not then it shouldn't have anything to do with it .
Have you checked your battery ?
Starter ?
Made sure your spark plug wires were pushed in all the way ?
Just a few simple things to check before you start freaking out
Old Oct 24, 2008 | 05:23 AM
sd_ej1's Avatar
Default Re: gsr help (99SlammedCivic)
he didnt unplug nothing
my battery seems to be working fine
sorry but how do u check the starter?!
and I'll check the spark plug wires today !!!
anything else bro?
thanks a ton !!!!
Old Oct 24, 2008 | 02:28 PM
thewrai6th's Avatar
Sounds like it's turning over, but not firing.
Do you have gas?
Do you have spark?
Do you have compression?
Do you have any CELs?
Don't let people drive your car, especially if they can't drive stick. The clunk of the engine stopping might have knocked a wire loose somewhere.
Did it start after it was stalled, or did it stall and that was it?
Old Oct 24, 2008 | 10:29 PM
sd_ej1's Avatar
Default Re: gsr help (thewrai6th)
it has gas
how do i check for a spark
and for the compression?
he stalled a couple times [pretty hard]
soo maybe he might of knocked something loose
any ideas???
Old Oct 24, 2008 | 10:30 PM
Snipper Snapper
Battery or starter !
Old Oct 24, 2008 | 11:13 PM
sd_ej1's Avatar
my bet is on the starter !!!
but how do you check for that ???
Old Oct 24, 2008 | 11:17 PM
Snipper Snapper
Have someone hit the starter w/ a hammer while u try to start it !
Its an old trick - Maybe u can take a video to help us better understand as to what it is doing !
Old Oct 24, 2008 | 11:24 PM
sd_ej1's Avatar
yeah umm ill get a video up soon !!!
the car cranks i guess
but just isnt firing up
iono if that makes sense?!
Old Oct 25, 2008 | 10:34 AM
sd_ej1's Avatar
allright i got a video
http://www.youtube.com/watch?v=l4bHlvva0LE
Old Oct 25, 2008 | 12:11 PM
thewrai6th's Avatar
Default Re: (sd_ej1)
It is not the battery or starter.
I meant check the spark plugs for gas.
And to check for spark... (have someone knowlegable help you or you will shock yourself) ...hold the plug to ground while starting the car and watch for spark.
Old Oct 25, 2008 | 02:20 PM
sd_ej1's Avatar
Default Re: (thewrai6th)
will do
do you think a fuse may be a reason???
Old Oct 25, 2008 | 02:22 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">will do
do you think a fuse may be a reason???</TD></TR></TABLE>
Could be possible.. I'd start with checking all the fuses under the hood and under the dash
Old Oct 25, 2008 | 02:23 PM
sd_ej1's Avatar
Default Re: (Jimmy)
yeah !!!!
has anyone heard of a mk4 supra fan on a koyo radiator
put on a gsr ???
Old Oct 25, 2008 | 04:43 PM
my_hidden_romance's Avatar
could be the coil pack or the dizzy in general sounds like ur not getting spark
Old Oct 25, 2008 | 06:20 PM
sd_ej1's Avatar
Default Re: (my_hidden_romance)
if it is
what should i do ?
Old Oct 25, 2008 | 06:30 PM
GainMpg1's Avatar
Is that an early 90's model?
My old Accord used to do that when the battery needed replacement.
Could be a fuse, or starter.
When did you last replace the sparkplugs/wires? They could be shot if they are real old.
Old Oct 25, 2008 | 06:37 PM
S1NFUL RL1 619's Avatar
Default Re: (GainMpg1)
my guess... the spark plugs
Old Oct 25, 2008 | 06:51 PM
sd_ej1's Avatar
its a 95 honda civic
with a 94 gsr
and the wires should still be new
sd_ej1's Avatar
Default Re: (S1NFUL RL1 619)
ima check that too
aye bro know any good shops in sd???
JessyJDMlover
Jun 4, 2012 10:33 PM
EtErNaL_dReAm
Feb 25, 2008 01:41 PM
zacatkings
27
Mar 22, 2006 05:26 AM
rainmanef
Jan 11, 2005 08:07 PM
Frito1
Apr 6, 2002 07:59 PM
