A Whole Lotta Noises..
Recently my car has been making a lot of weird noises..on the passenger side front wheel area there is a fast constant clicking...the clicking gets faster as i go faster..i recently changed the rotors to aftermarket ones, but i took of the tire and it seems to be fine..
also when in the car, you can hear another clicking sound..im thinking its from under the dash..my VSS or throttle cable squeaks but i dont think that it..
any ideas?
any ideas?
As far as the clicking noise.. do you ever feel any vibration upon acceleration? You need to inspect your axles and cv boots..
(make sure there are no rips/tears in the boot, look for grease slung around,etc)
I've never heard of an issue where the VSS ''squeaking''.. for the throttle body.. try shooting a little bit of wd-40 and see if that helps any..
absolutely. as your axles get worse and sling out more grease theyre going to start clicking and eventually they will seize up. NAPA sells re manufactured axles for like 50 bucks. i would get ASAP before something catastrophic happens..
ra64
Mar 8, 2015 09:45 AM
both my CV boots are ripped and my car makes a clicking noise when i accellerate. did i do some dama
civicracer1993
Dec 29, 2002 10:24 PM
