1990 b16A compressor, power steering pump, mount, gaskets
Parts were removed from engine with around 40,000 miles on it.
No longer have the motor and have no use for extra parts.
Call me at 201-575-0784: John OR email me at DANEMESLS@aol.com
Pictures of the parts are on this myspace website.
Click pictures and they are under the B16A parts album.
http://profile.myspace.com/ind...08396
Parts will be removed at pick up when you come by, allow time for removal.
Only serious buyers, sale on price agreed on only, cash only.
Don't show up with cash less than agreed on.
Parts assumed are in working condition, everything else worked when I bought the motor, these were removed because my vehicle did not have these option when I did the motor swap. (From a 1990 JDM B16A Motor) OBD-0
1. Power steering pump with brackets, and oil line attached! (PR3.094972N)
2. Air conditioning compressor, brackets and pulley attached.(Belt)
3. Half Shaft.
4. Stock motor mount Plate.
5. May have bolt to mount to you motor if car is brought to match up if necessary.
6. Gaskets for the v-tech solenoid and valve cover listed below:
1988-1991 (XSi) OBD-0 B16 require both vtec solenoid gaskets from a 91 Acura NSX. (Genuine Honda Parts.)
Smaller Upper Gasket: #36172-PR3-005 Selling brand new in bag
Large gasket: #15825-PR3-005 (used, no ripped screen perfect, use with rtv blue seals like new.)
Large gasket Civic SI Thickert: #15825-P08-005 (used, not ripped screen slightly dented, use with rtv seals like new.) Never used because it was wrong gasket for obdo motor.
Used B16 valve cover gasket. And 4 Spark plug Gaskets.
Use with rtv won’t leak, quick fix for burnt out gaskets, without. Still in good shape
Modified by crxb16d2 at 11:06 PM 10/23/2008
john_racer
Jun 14, 2004 02:31 PM
15825pr3005, 1991, ac, acura, air, b16a, buy, compressor, cond, gasket, nsx, power, powersteering, sale, steering
