Scale of 1-10 how hard is it to replace hub bearings......105K figure why not.
Just want to know what issues I am going to run into.
(Mech skills= Capable of pulling apart and engine and reasembling in working order)
its not that hard because you dont replace the bearing yourself all you do is take the hub off the car and then drop it off at a shop. the bearing needs to be pressed out and a new one needs to be pressed back in. i just did this on my car, the hardest part if getting the axle bolt off.
keith
keith
unless there making some noise (usully a whining noise around 40 mph) there is no need to replace them they may go for another 100k or so.
Guest
Posts: n/a
........................... the hardest part if getting the axle bolt off.
keith
keith
HAHAHHAHAHAHHAHA..... Soooooooooooo true.
And you gotta watch out for those different sized brakes too..... Right Keith???
Smoothy
Mar 29, 2003 02:53 PM
