Brake Info Needed
Old Oct 23, 2008 | 04:34 AM
UK Accord's Avatar
Default Brake Info Needed
What are the difference between the brakes in the US Accords.
90 - 93
94 - 97
98 -02
The reason I ask is because I'm looking to buy a Brake Kit from http://www.revolutionbrake.com/ and I need to make sure I get the right kit.
The EDM Accord 93 - 98 which I own has 282mm discs/rotors up front and 260mm discs/rotors rear.
I'm sure the 90 - 97 front kit will fit my car but I'm not sure if the 98 - 02 rear would.
Any one with any info please let me know.
Old Oct 23, 2008 | 09:16 AM
P_Adams's Avatar
Default Re: Brake Info Needed (UK Accord)
IF your bolt pattern is 4 x 114.3mm, then your EDM Accord uses the equivilent of the '94 Accord (Front Application 282mm) Front brake rotor
It also shares the equivilent rear disc with all '91 thru '97 Accords with rear disc Brakes (Rear Application 260mm)
With that info and the confirmation on your bolt pattern, any "Big Brake Kit" for the USDM '94-97 EX (w/rr disc) should work.
If you have to go to a five (5) lug, the equivilent application in the USDM market will be the '98 thru '02 Accord (5 lug (v6 ect)
P
Old Oct 23, 2008 | 11:07 AM
UK Accord's Avatar
Default Re: Brake Info Needed (P_Adams)
Thanks for the information, yes the EDM Accord does have the 4x114.3 stud pattern.
The kit they list is for the 90 - 97 Accord http://store.revolutionbrake.com/hoac19sheduf.html
Modified by UK Accord at 12:21 PM 10/23/2008
Old Oct 23, 2008 | 12:28 PM
P_Adams's Avatar
The only additional question you may wish to query your vendor about is Wheel / Caliper clearance.
Some of the Big Brake Kits require going +Plus Sized on the Road wheels for this reason. I notice they haven't mentioned anything and you may find the answer in their FAQ's section. I just don't want you to pay the shipping to the UK to find you're behind the 8 ball.
P
Old Oct 23, 2008 | 02:02 PM
UK Accord's Avatar
They state that 17" Alloys are required.
I cuurently have on a set of White 17" Rota Grids.
Thanks for your help P_Adams just got to wait until the £ gets back stronger against the $.
Old Oct 23, 2008 | 02:31 PM
1992Si's Avatar
Default Re: (UK Accord)
One other option is just buy better rotors and pads for your OEM brakes.
We ran brembo sloted rotors and Axxis pads on our drag car and had no problems stopping from 140+mph.
http://www.axxisbrakes.com/
Old Oct 23, 2008 | 02:41 PM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK Accord &raquo;</TD></TR><TR><TD CLASS="quote">They state that 17" Alloys are required.
Thanks for your help P_Adams just got to wait until the £ gets back stronger against the $.</TD></TR></TABLE>
Check the offsets of the wheels as well. Just because it's a 17" doesn't mean the offset will allow it
Old Oct 24, 2008 | 12:18 AM
UK Accord's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">One other option is just buy better rotors and pads for your OEM brakes.
http://www.axxisbrakes.com/</TD></TR></TABLE>
I have uprated discs and pads all round and the stopping power is questionable. Plus how good do big rotors look behind wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">
Check the offsets of the wheels as well. Just because it's a 17" doesn't mean the offset will allow it </TD></TR></TABLE>
Offset is 42
Old Oct 24, 2008 | 04:16 AM
P_Adams's Avatar
I had to go to Carbon/Kevlar pad sets before I could get consistant braking action. I went the slotted / vented rotor route myself. These actually get better the harder I work them.
The appearance won't be objectionable, All anyone will see will be the painted calipers anyway
P
Old Oct 24, 2008 | 05:45 AM
Offset is 42
*should * be good, my Volks clear the NSX calipers and they're +43 if I recall.
What brakes were you thinking about running?
Old Oct 24, 2008 | 07:53 AM
UK Accord's Avatar
Old Oct 24, 2008 | 07:55 AM
Ballin!
Old Oct 24, 2008 | 07:57 AM
P_Adams's Avatar
Default Re: (TheMuffinMan)
I believe he's looking at these:
P
Old Oct 25, 2008 | 09:50 AM
gotusukin's Avatar
i have a 97 accord 2dr coupe manual..
wen i pull off my abs light goes on and stays on and if off wen i brake it will pulsate den light will come on to help brake.
Is there sumthing i should check to find out wat it might be.
Old Oct 25, 2008 | 10:23 AM
UK Accord's Avatar
Try starting your own thread maybe.
bananaphone88
Nov 8, 2017 12:09 PM
krt671_cb7
Mar 18, 2010 07:01 PM
Elvis1977
Aug 25, 2009 06:01 AM
SCoutZ
Nov 20, 2007 03:12 AM
B18C5EK
Dec 7, 2002 06:32 PM
