hey i really need help, 92 DA wont start unless push started. please help me
Old Oct 22, 2008 | 10:06 PM
rollinonblades's Avatar
Default hey i really need help, 92 DA wont start unless push started. please help me
hey i just traded my 94 integra for a 92 integra, anyway. and the thing will not start what so ever with the key, it will only push start. when you turn the key over all i hear is a click, sounds like its trying to use the starter but i think it may be [freak]ed up... all i hear is clicking with turnin the key, no attempt to start... and the check engine light is on. and the guy also said afterwords theres no 02sensor... not sure what that is so anyway, PLEEEEEEASE HELP ME i really need it... any tips will help me. im stuck with a push starting car....
Old Oct 22, 2008 | 11:21 PM
jturbo8316's Avatar
Default Re: hey i really need help, 92 DA wont start unless push started. please help me (rollinonblades)
Sounds like the starter went bad, so just get a new one and it'll start up like a champ every time. You could get an 02 sensor and it will make the check engin light go off but the car will run fine with out it. I dont know what the smog laws are out there but to pass a smog test you will need an 02 sensor.
Old Oct 22, 2008 | 11:23 PM
Default Re: hey i really need help, 92 DA wont start unless push started. please help me (jturbo8316)
alright man, yeah its weird all i hear when i turn it over is click.... and sometimes a few clicks, but it sounds like its coming from under the dash.... how much does a b18a1 starter cost???
Old Oct 22, 2008 | 11:55 PM
virdizzeripsta's Avatar
im pretty sure ebay has some
Old Oct 23, 2008 | 12:33 AM
racebum's Avatar
Default Re: hey i really need help, 92 DA wont start unless push started. please help me (virdizzeripsta)
double check the main lead from your battery to the starter. the clicking is likely the silanoid. either the motor is bad, the lead has came undone or your batter is dying due to a bad alternator.
Old Oct 23, 2008 | 12:47 AM
Mfoehrkolb's Avatar
Your starter has a solenoid on it. Take a small hammer or something with some weight and just tap/bang on it a couple times. It should start right up then.
This isn't a fix, but it's temporary to get to A to B.
Check your grounds, and all connections also.
My girls SI wouldn't start because of stupid corrosion on her ground right next to the starter.
Old Oct 23, 2008 | 01:03 AM
Default Re: (Mfoehrkolb)
well i have full power to everything else to the car, like the lights inside, the head lights, (and also the headlights are extremely messed up, the right fog light and head light are EXTREMELY dim, like wayyyy dim, but they do work that was another question i was going to ask) and the radio, all that works, so i'll try that tapping on the starter method, but if that doesnt work what is my best bet on doing, im trying to save as much money as i can because i dont have any lol. so what should i do next if that doesnt work, what kind of test's can i personally do to figure this out??? and how do i check the alternator, and check to see if the battery is dead???
Old Oct 23, 2008 | 10:01 AM
Mfoehrkolb's Avatar
Default Re: (rollinonblades)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">well i have full power to everything else to the car, like the lights inside, the head lights, (and also the headlights are extremely messed up, the right fog light and head light are EXTREMELY dim, like wayyyy dim, but they do work that was another question i was going to ask) and the radio, all that works, so i'll try that tapping on the starter method, but if that doesnt work what is my best bet on doing, im trying to save as much money as i can because i dont have any lol. so what should i do next if that doesnt work, what kind of test's can i personally do to figure this out??? and how do i check the alternator, and check to see if the battery is dead??? </TD></TR></TABLE>
--- Let me add this. When it was just her ground... Her headlights were dim and also some of her cluster lights. Everything worked perfectly fine though. Kinda sounds similar.
Old Oct 23, 2008 | 11:53 AM
yeah the cluster lights are completely fine, and when i push start the car, the lights are still messed up... yeah i tried hittin the starter, the only thing i got from it was a little click from the starter when i tried to start it.. so does that say anything? how hard am i supposed to tap the starteR?
Old Oct 23, 2008 | 12:12 PM
benwadb1's Avatar
Its probably an under dash relay, anyway run a large guage wire at least 8 from the battery or the pass side fuse block main to the starter solenoid and then attempt to start your db1
Old Oct 23, 2008 | 01:26 PM
benwadb1's Avatar
Default Re: (benwadb1)
Another thing to check would be the clutch interlock switch, and to bypass the ignition switch you could run a jumper wire from the battery to the tab on the soleniod were the black and white is and it should turn over. Just make sure its in nuetral.
Old Oct 23, 2008 | 02:24 PM
alright i had a breakthrough!!!!! alright i seen this dude on another forum saying that his car would try and turn over at all (like mine, it does not attempt to turn) and what he did was he left it on the II position, as if the car was started ya know? and left it for like 5-10 mins, and then it would start up right? i tried that, a couple times, and one time it worked, it turned over no problom and started.... now it wont do it again, so i know the starter works, but what would make it do that, leavin the key on the II position for awhile and have it start? what do i need to do now?
Old Oct 23, 2008 | 02:40 PM
Local's Avatar
I had the same issue & it was one of the grounds right near the starter. Check all your grounds first and make sure they are still perfect and not all corroded like mentioned above.
goodluck
Old Oct 23, 2008 | 04:10 PM
Default Re: (Local)
alright how do i check the ground??? does anyone have a picture of where the ground is on the starter???? and how do i see if the ground is good?
Old Oct 23, 2008 | 04:37 PM
NorthWest94Teg's Avatar
Hey if you still need help man, call me and come by my house. I sent you a message on myspace earlier. let me know, Later. Aaron
Old Oct 23, 2008 | 10:26 PM
MasterLsGod's Avatar
i have an alternator that i am selling with brackets for 40 bucks....
Old Oct 24, 2008 | 12:10 AM
Local's Avatar
Default Re: (MasterLsGod)
there should be a bolt holding in the starter ground & battery ground if i remember correctly... its under the battery tray. its easier to take the tray out to get to them
Old Oct 24, 2008 | 04:32 AM
90SiReX's Avatar
in my DA there was a clicking sound,the car didnt start and threw a CEL. i was thinking main relay since it came from under the dash. turns out it was some 7.5amp fuse that blew as well as the ECU fuse under the hood. check em. GL
Old Oct 24, 2008 | 07:03 PM
Default Re: (90SiReX)
alright well check this out, my igintion itself (where the key goes) is really loose, and i was [freak]in with it and i was moving it around, then it started!!! but it wont start again, so theres something fishy about the ignition... and also theres a blue light flash inside the ignition.... sooo not sure what it is anymore..
Old Oct 24, 2008 | 07:30 PM
steveo135's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">and also theres a blue light flash inside the ignition.... sooo not sure what it is anymore.. </TD></TR></TABLE>
blue light as in electical spark?
Old Oct 24, 2008 | 08:52 PM
Default Re: (steveo135)
yeah, and it only sparks when i hear the starter clicking, when i hear no clicks under the hood or the dash, i dont see a spark, but when i hear it, i do see the blue electrical flash... i know it has something to do with the ignition, cause i've started the car twice with the key, other times have only been pushing it... so when i move the ingition key around it sparks and in some places it wont do anything.... what should i do?? should i buy a new ignition???
Old Oct 25, 2008 | 05:42 AM
IowayRUlz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">alright i had a breakthrough!!!!! alright i seen this dude on another forum saying that his car would try and turn over at all (like mine, it does not attempt to turn) and what he did was he left it on the II position, as if the car was started ya know? and left it for like 5-10 mins, and then it would start up right? i tried that, a couple times, and one time it worked, it turned over no problom and started.... now it wont do it again, so i know the starter works, but what would make it do that, leavin the key on the II position for awhile and have it start? what do i need to do now?</TD></TR></TABLE>
This almost seems like a fuel pump issue. Perhaps the pump is going out and can't build pressure or the relay is bad. Car still on the original pump?
Seems like a few different issues going on (I'd check your starter and battery too).
Old Oct 25, 2008 | 11:30 AM
pokmijn's Avatar
Default Re: (IowayRUlz)
if you push start it and it works then its most likely your starter. replace that and call it a day. no way it will be your alternator cause if it is it will drain your battery and you wouldn't be able to push start it i know it happened to me.
Old Oct 25, 2008 | 11:34 AM
Da9Gro's Avatar
Default Re: (pokmijn)
check the wire to the starter solenoid, has a habit of coming loose
Old Oct 25, 2008 | 07:25 PM
civic_teg's Avatar
New User
check your battery and your starter one of the two is bad
