JDM front end...what hood latch to use???
Old Oct 22, 2008 | 09:38 PM
Green_Goblin's Avatar
Default JDM front end...what hood latch to use???
Hey guys, I have a 1998 Integra with a JDM front end and trying to figure out if I can use the stock Integra hood latch and cable or if I need one off a JDM integra or civic, etc.? Thanks in advance
Old Oct 22, 2008 | 09:48 PM
maxwellmercer's Avatar
i believe you need the JDM hood latch!!
Old Oct 22, 2008 | 11:32 PM
sjbmx's Avatar
Default Re: JDM front end...what hood latch to use??? (Green_Goblin)
do a search. a da one will suffice though.
Old Oct 22, 2008 | 11:53 PM
virdizzeripsta's Avatar
Default Re: (maxwellmercer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxwellmercer &raquo;</TD></TR><TR><TD CLASS="quote">i believe you need the JDM hood latch!!</TD></TR></TABLE>
you need a jdm hood latch
Old Oct 23, 2008 | 01:13 AM
BOOST3DTEG's Avatar
I just recently did a JDM front end on my car and I went to the dealership and bought a DA latch cable. It is much longer then the normal DC one so I would just buy the DA and not waste your time finding a JDM latch since it might be more expensive and may take awhile to get.
Old Oct 23, 2008 | 08:45 AM
Default Re: JDM front end...what hood latch to use??? (BOOST3DTEG)
a jdm hood latch is only like 40 dollars.
Old Oct 23, 2008 | 07:50 PM
ls2typer150's Avatar
the da hood hatch works i used it on my jdm front conversion
Old Oct 23, 2008 | 10:22 PM
MasterLsGod's Avatar
da's rules
Old Oct 23, 2008 | 10:42 PM
MugenDC4's Avatar
I used my OEM one and bent it slightly to fit the hood and use a DA cable.
Old Oct 23, 2008 | 11:04 PM
moosta936's Avatar
DA latches work, to use the oem one you could just turn it around for a temporary solution.
Old Oct 24, 2008 | 01:19 PM
jdmfrontTEG's Avatar
A jdm hood latch is the same as the usdm hood latch. On the jdm rad. support it is just on the opposite side facing the other direction. You can reroute your cable from your fender well to your engine bay. It will also help stop thieves.
Old Oct 24, 2008 | 02:01 PM
illicit_kustomz's Avatar
Thats exactly what I did on my teg. Just used a dc latch and bent it a lil bit and ran the cable through the engine bay..
Old Oct 24, 2008 | 02:48 PM
trepteg's Avatar
Nice to see that I can use the DA cable because I open my hood manually .. loll
d15champ
Paint and Body
Feb 6, 2010 08:28 AM
sti grip
Aug 1, 2008 09:39 AM
Ilovemyef9
Feb 22, 2007 07:26 AM
i hav an ef
Sep 5, 2004 02:52 PM
Stryker
Jul 8, 2004 09:08 AM
