Automatic to Manual EG HB Swap
Old Oct 22, 2008 | 08:50 PM
DaMastaDoN's Avatar
Default Automatic to Manual EG HB Swap
Im goin Manual and i need a list so i can get everything i will need to swap my EG HB auto/tranny into a manual/tranny im have a B18B1 im bout to drop in and i need to know any complications or anything i may run into. If you know pricing that would help too.
Old Oct 22, 2008 | 09:02 PM
iamthefollower's Avatar
Default Re: Automatic to Manual EG HB Swap (DaMastaDoN)
If you have the motor without the tranny it is probably going to run you anywhere from $500-$900
Your going to need...
Hydro Tranny....
Half Shaft-94-01 Integra or 99-00 Si.
Axles for ^^^^^^^^^^^^^^^^^
Shift Linkages from any integra from 1990 to 01 or the 99-00 Si.
The Back L mount for a 94 or 95 integra or the 93-95 b16 del sols... the integras from 96-01 and the Si's back mount are about 2 inches shorter than what you are going to need. So get the one from 94 or 95.
To go from Auto to Manual you can actually buy the top tranny mount so that you don't have to cut and weld anything.. If you want i'll get a site for you to go to and check out the mount.
Old Oct 23, 2008 | 06:48 AM
94EG8's Avatar
Seagull Management
Default Re: Automatic to Manual EG HB Swap (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">The Back L mount for a 94 or 95 integra or the 93-95 b16 del sols... the integras from 96-01 and the Si's back mount are about 2 inches shorter than what you are going to need. So get the one from 94 or 95.</TD></TR></TABLE>
False. All '94 - '01 integra mounts and brackets are the same. The rear T/L bracket definately works. '94 - '97 Del Sol Vtec rear T/L bracket will also work. '99 - '00 Civic Si brackets are shorter and don't work. As for the shift linkages '94 - '01 and '99 - '00 Si both work. Del Sol Vtec shift linkage definately doesn't work. and i've never heard of anyone using '90 - '93 integra linkages, thats not say they don't work, but i've never heard of it being done and I suspect they wont work.
Old Oct 23, 2008 | 11:16 AM
Default Re: Automatic to Manual EG HB Swap (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
False. All '94 - '01 integra mounts and brackets are the same. The rear T/L bracket definately works. '94 - '97 Del Sol Vtec rear T/L bracket will also work. '99 - '00 Civic Si brackets are shorter and don't work. As for the shift linkages '94 - '01 and '99 - '00 Si both work. Del Sol Vtec shift linkage definately doesn't work. and i've never heard of anyone using '90 - '93 integra linkages, thats not say they don't work, but i've never heard of it being done and I suspect they wont work.</TD></TR></TABLE>
Sorry I know that I bought a 94 or 95 back L mount for mine, and YES the 90-93 linkages DO work because I have a set in MY car. I didn't know about the 96 up integras I figured ppl would use those along with the SI back mount for there obd2 swaps.. I don't really mess with anything past 95 so sorry guy.
JediKnight4life
Jun 24, 2008 12:28 PM
DA3
Apr 18, 2008 02:55 PM
teal_dx
Feb 3, 2007 10:44 AM
boredracer408
Feb 10, 2006 06:56 PM
RICE POLICE SIP
10
Jan 7, 2003 09:05 AM
