kinife-edge crank (did search)
Old Jul 29, 2002 | 12:57 PM
Boostless97Lude
Guest
Posts: n/a
Default kinife-edge crank (did search)
ok, in one of these forums (can't remember which one, i think it was Prelude) someone told me that a knofe-edge crank it a bad idea w/ turbo. everything else i've ever heard/read has said it's a good idea b/c it lightens the cranks and helps reduce turbo lag like a lightweight flywheel etc etc. since thise is the FI forum, let me in on what you guys know
Old Jul 29, 2002 | 01:49 PM
DRAGLS's Avatar
Default Re: kinife-edge crank (Boosted97Lude)
it useful for n/a applications
Old Jul 29, 2002 | 02:04 PM
93LSivic's Avatar
Also it cuts down on oil vapor in the oil pan.
Old Jul 30, 2002 | 04:10 AM
Boostless97Lude
Guest
Posts: n/a
but why do people say not to do it with hondas, or not to do it with turbo>?
Old Jul 30, 2002 | 08:14 AM
CHEETAH's Avatar
any crank which sees hgih rpms like the honda vtecs, needs to be strong, by knife edging it weakens the crank considerably. Only racers usually do this since the car is not daily driven, etc.
greg
Old Jul 30, 2002 | 04:25 PM
rioninja's Avatar
Its much cheaper and safer to go with a lightweight flywheel. Only do the crank if your looking to shave off every last bit of rotational mass.
Also, the crank DOES NOT run through the oil in hondas. On top of that, most Hondas have factory windage trays which just about eliminate interferance with the oil. Knife edging is popular in the domestic croud, where the actual crank runs through the oil and creates a lot of resistance and frothing of the oil. On a honda the only advantage would be weight. And really, the sharp edge of the crank does practically nothing. Its just the removed material.
greyEG
16
May 22, 2013 01:38 AM
zakura R
Oct 13, 2010 06:55 AM
95dcsleeper
Sep 5, 2005 06:48 PM
NERV
Sep 16, 2004 07:49 AM
nwarp
Aug 2, 2002 10:44 AM
