Drivers side mount bracket interchangeable GSR/B18B
Old Oct 22, 2008 | 06:59 PM
GSR-EG-92's Avatar
Default Drivers side mount bracket interchangeable GSR/B18B
I have a JDM B18C that will only work with a 3-hole driver side mount, I have a brand new 2-hole mount only.
So can I use a 2-hole bracket from a B18B on my GSR block? Direct bolt-in?
Old Oct 23, 2008 | 05:42 AM
God-Driven's Avatar
if you are putting the motor into an EG you need the gsr braket and motor mount, and if is going into a DA you need the DA braket and motor mount.
Old Oct 23, 2008 | 06:14 AM
weavertime1's Avatar
Default Re: Drivers side mount bracket interchangeable GSR/B18B (GSR-EG-92)
I don't remember B18Bs coming with two hole mounts...the GSR block mount and three hole chassis mount will work fine on the ls block.
Adinfinitum
Apr 14, 2008 12:48 PM
NSfit
Nov 9, 2006 06:02 AM
VTC_CiViC
May 17, 2004 01:24 PM
