Suspension & Brakes Theory, alignment, spring rates....
asr with 22mm type r bar
Old Oct 22, 2008 | 06:44 PM
91bluehatch's Avatar
Default asr with 22mm type r bar
i just ordered the complete type r rear sway bar kit http://jhpusa.com/store/pc/vie...=3817 to go with my asr rear subframe brace. Now Im hearing that it wont work? Does anyone have any imput on this?
Old Oct 22, 2008 | 07:04 PM
khallilD's Avatar
Default Re: asr with 22mm type r bar (91bluehatch)
i've seen it done here on honda-tuning i dont see why it wouldn't work just make sure the the thread pitch for the d-brackets is the same
Old Oct 22, 2008 | 07:08 PM
khallilD's Avatar
yea i lust looked at your link and it seems to be the same size and shape as the ASR sway bar which i have on my car
Old Oct 22, 2008 | 07:16 PM
Default Re: asr with 22mm type r bar (khallilD)
So i should be able to use everything that come with the kit with no problems then?
Old Oct 22, 2008 | 07:26 PM
Linh.'s Avatar
yes it will work
Old Oct 22, 2008 | 08:08 PM
khallilD's Avatar
yea as long as your lca's have provisions for the endlinks
Old Oct 22, 2008 | 09:15 PM
k thanx guys! Cant wait to put it on!
Old Oct 23, 2008 | 07:47 AM
goofke's Avatar
with the ASR brace are you able too use any oem swaybars?
and what will happen if you only put a swaybar on the back?
Old Oct 23, 2008 | 11:27 AM
khallilD's Avatar
Default Re: (goofke)
you should start your own thread but depending on the size of the swaybar generally anything bigger than 20 millimeters. eventually you will tear up your subframe and yes i beleive any oem bar will work
Old Oct 23, 2008 | 11:35 AM
feeldabazzgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khallilD &raquo;</TD></TR><TR><TD CLASS="quote">yea as long as your lca's have provisions for the endlinks</TD></TR></TABLE>
X2..it will work just make sure your rear LCAs have mounting hole for endlinks
Old Oct 24, 2008 | 07:45 AM
Cjdcivic's Avatar
Everything should work fine. Have the same set up on my hatch. Absolutely love it.
JohnQPublic
Suspension & Brakes
Aug 18, 2006 06:53 AM
PTR1
Apr 28, 2004 08:44 PM
supapoopa
12
Jan 16, 2004 07:15 AM
Mr. Thunderlips
Feb 7, 2002 10:34 AM
swarsing
Nov 7, 2001 12:08 PM
