Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!!
Old Oct 22, 2008 | 06:40 PM
gsrhatch2356's Avatar
Default Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!!
So its been a while since I took this motor apart but was going through some pics and found these so I thought I would post so everybody could see.
I met this guy through a friend and he said that he misshifted and hit 10k rpms, the pics speak for themselves.
When i took the head off this is what I saw ONLY THREE PISTONS!!!!
You can see it better here
I found it though!!!
This all started with valve float then broke off the head off one of the valves and shot it back and forth and chewed everything up
This is the remaining pistons, you can see the rod is bent to all hell
crappy pic but it is a close up
this is one of the pistons and it is cracked all the way down the side
So if we didnt learn anything then make sure you post your pics when you rap it out on stock vlave springs!!
Old Oct 22, 2008 | 06:43 PM
iamthefollower's Avatar
Default Re: Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!! (gsrhatch2356)
Yeah I bet he puts a rev limiter on it now. That is nuts, I know a guy here that had head work done to his b16, new valves, ported and polished, cams and all, put his sons ecu in it with no rev limiter, missed 2nd and there went all that money... sucks man.
Old Oct 22, 2008 | 06:45 PM
lluks_844's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 &raquo;</TD></TR><TR><TD CLASS="quote">So if we didnt learn anything then make sure you post your pics when you rap it out on stock vlave springs!! </TD></TR></TABLE>
I was upset until i read that lol.
Ive seen 10k once wasnt as fun as i thought.
Old Oct 22, 2008 | 06:52 PM
94EG8's Avatar
Seagull Management
Default Re: Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!! (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I bet he puts a rev limiter on it now.</TD></TR></TABLE>
Rev limiter wont help you one bit if you miss a shift, sure it'll cut off fuel to the injectors, but the engine will spin over faster than the rev limiter would normally permit.
To the OP, Wow, just wow.
Old Oct 22, 2008 | 07:00 PM
Import_spoon's Avatar
Could that block be fixed if you get new cylinder walls and new pistons in the block. Can the head be remachined?
Old Oct 22, 2008 | 07:01 PM
Default Re: Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!! (94EG8)
yea it was a 99 si, and he didnt have the money to get a new one or pay me to install it so out of the kindess of my heart I put in a ls motor he got for pretty cheap and he gave me the b16 and the ls trans. so I got like 18 bucks for scrap cause I didnt take the crank out so I got dirty alum price but all in all the cams were still good and I got to reup my honda bolt collection including little things like crank pulley key and crap like that.
Old Oct 22, 2008 | 07:03 PM
Default Re: (Import_spoon)
You know I was wandering the same thing about the block, maybe getting it sleeved but due to the excessive damage you just dont want to invest in something that is iffy. as for the head it was trash there was no saving it at all.
Old Oct 22, 2008 | 08:07 PM
turbojdmhatch's Avatar
Default Re: (gsrhatch2356)
awaiting "TravisCadello" to come in and start saying a d series would have held up to 10k
Old Oct 22, 2008 | 08:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">I seen a video of a D with no oil and water in the oil. no header. no rev limiter. and no radiator rev to like 10000 rpm for 15-30 till it blows</TD></TR></TABLE>
Old Oct 22, 2008 | 08:12 PM
Default Re: (turbojdmhatch)
lol i know the vid. he's talking about, it's a 1.5 on youtube.. but i think it did have a rev limiter though.
Old Oct 22, 2008 | 08:23 PM
Default Re: (iamthefollower)
yea its in a different language i think french...we all have seen the video its just that kid is about the stupidest honda tech member to ever join and talks out of his *** on everything
SOHC_4dr's Avatar
i think i seen it to. was it in a 5th gen blue sedan?
Old Oct 22, 2008 | 08:25 PM
lol ohh gotcha, i think it was actually in a white car.. don't really remember though.
Old Oct 22, 2008 | 08:26 PM
Default Re: (SOHC_4dr)
no im pretty sure it was a cx hatch....im pretty sure
cliff: all of his posts were locked today thanks to this guy all thanks can be sent PM i will accept paypal
Old Oct 22, 2008 | 08:31 PM
EJ8_Enthusiast's Avatar
this has to sound really bad, but could someone explain "missing a shift".
3 month civic owner and I shift at like 3k, 4k max.. how do you even justify going over 6k??? just seems crazy to me.
Old Oct 22, 2008 | 08:34 PM
Default Re: (EJ8_Enthusiast)
its when ur racing, ur car can handle so many rpms but when you are shifting so fast sometimes you miss the gear ur going to..
Old Oct 22, 2008 | 08:36 PM
Adankid's Avatar
misshifting sucks major bawls!!
i've seen 9k+ 12 times. :D
Old Oct 22, 2008 | 08:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">this has to sound really bad, but could someone explain "missing a shift".
3 month civic owner and I shift at like 3k, 4k max.. how do you even justify going over 6k??? just seems crazy to me. </TD></TR></TABLE>
just go to a track or be a ricer one day and find a street race ahha
it usually means they shift....1.....2....3.....2.4..........first second third back into second then into fourth like they intended....some people tend to do it when they have a short shifter
Old Oct 22, 2008 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbojdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">
just go to a track or be a ricer one day and find a street race ahha </TD></TR></TABLE>
lol... funny....
Old Oct 22, 2008 | 08:57 PM
Adankid's Avatar
i have a short shifter, and i've never gone from 3rd to 2nd.
that sounds dangerous!
Old Oct 22, 2008 | 09:11 PM
Default Re: (Adankid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid &raquo;</TD></TR><TR><TD CLASS="quote">
that sounds dangerous! </TD></TR></TABLE>
yes sir, I know a guy that did it and messed up a valve in his head, just for going back to 2nd instead of 3rd... luckily that's all he messed up... He sold the car and told the guy it had a cam in it
Old Oct 22, 2008 | 09:14 PM
dividedas1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid &raquo;</TD></TR><TR><TD CLASS="quote">i have a short shifter, and i've never gone from 3rd to 2nd.
and it is...
i don't think he meant they purposly shift from 3rd to 2nd. i think he was trying to say with a short shifter it seems to be a little bit easier to miss a shift especially in the "heat of the moment" lol
Old Oct 22, 2008 | 09:18 PM
Adankid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 &raquo;</TD></TR><TR><TD CLASS="quote">
and it is...
i don't think he meant they purposly shift from 3rd to 2nd. i think he was trying to say with a short shifter it seems to be a little bit easier to miss a shift especially in the "heat of the moment" lol</TD></TR></TABLE>
thats sad.
for liars.
Old Oct 22, 2008 | 09:21 PM
thats sad.
for liars.</TD></TR></TABLE>
Yep, I told the guy what happened that bought it though... he def. wasn't happy but who would be ya know.... I didn't know he was buying it or I would've told him before he did.
Old Oct 22, 2008 | 09:22 PM
dividedas1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid &raquo;</TD></TR><TR><TD CLASS="quote">thats sad.
what are you talking about... who is lying? lol asides from the people that say short shifters are sweet
