D15Z1 out and in D16a6
Old Oct 22, 2008 | 03:46 PM
krysted9354's Avatar
Default D15Z1 out and in D16a6
ok whek swapping out my d15z1 im installing a D16a6 with z6 head and zc pistong etc HIGH COMP SOHC BUILD, wondering can i use my d15 motor mounts or not ?? and because my vx was a z1 vtec-e i dont need to do vtec wiring for the z6 do i ?? just p28 ecu and oxygen sensor conversion right ??? any info would be GREAT !!! thanks
and last will the d15z1 distributor work on the d16z6 head ?
Old Oct 22, 2008 | 03:49 PM
Default Re: D15Z1 out and in D16a6 (krysted9354)
anybody ?
Old Oct 22, 2008 | 04:05 PM
bump
Old Oct 22, 2008 | 04:45 PM
IndySporty's Avatar
Yes you can use all your old mounts, provided you swap the brackets over to the new engine. Yes you can plug and play the Mini-Me, as long as you do the O2 conversion. And last, no the distributor will not work without tweaking the holes in the dizzy a little bit with a dremel. That's what I always do when using a different head and I've had great success with it. Good luck and be ready to go a lot faster!
Old Oct 22, 2008 | 05:19 PM
94EG8's Avatar
Seagull Management
Default Re: D15Z1 out and in D16a6 (IndySporty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">And last, no the distributor will not work without tweaking the holes in the dizzy a little bit with a dremel.</TD></TR></TABLE>
Both distributors are actually the same. D15B7 and D15B8 are different and need to be hacked up to fit though.
Old Oct 22, 2008 | 05:23 PM
thanks for info, yeah im usind zc pisons and thin gaket all bismit head etc, ok thanks
Old Nov 16, 2008 | 10:26 AM
dfoxengr's Avatar
Default Re: (krysted9354)
PMed. I want to buy the z1 swap. email me at sales@foxraceco.com
thanks
Eman919
Dec 13, 2005 02:52 PM
tgjpwa
10
May 30, 2005 01:05 PM
thenick
Sep 25, 2004 07:20 AM
CRXSiR71777
Feb 29, 2004 09:25 PM
dlric
Jan 27, 2002 10:03 AM
