Overheating Hatchback - Awesome! - Help?
Old Oct 21, 2008 | 06:52 PM
r0cket247's Avatar
Default Overheating Hatchback - Awesome! - Help?
Here is the story.
I have a 95 Civic hb cx (w/ jdm d15). Car started to overheat. I heard a whistling noise coming for the radiator cap (plus it was really beat up). I saw drips of fluid leaking for the radiator cap area. So I replaced the radiator cap, but car still overheated. Next, I had a spare radiator laying around so I swapped that in. Car seemed fine, I drove around for 30mins and no problems arose. Ten minutes later I turned the car back on and test drove it again. As I approached 60mph the car started to cross the half way point and kept climbing. I turned on the heater and headed home.
Any suggestions? No radiator fluid leaks. The cooling fan turns on. Both of the hoses were hot (upper/lower).
Thanks in advance.
Old Oct 21, 2008 | 06:57 PM
slo_hatch's Avatar
Default Re: Overheating Hatchback - Awesome! - Help? (r0cket247)
check the obvious first...thermostat and leaky hoses. btw...did you bleed the system? and did you get a honda thermostat?
thechineseone
Mar 16, 2009 09:33 AM
JDM_SOHC
Oct 12, 2008 07:24 AM
94eg!
14
Sep 13, 2006 04:19 PM
slikz714
Jul 12, 2006 03:40 AM
IA95civicDX
Sep 10, 2005 10:21 PM
