slight knock on start-up
Old Oct 21, 2008 | 12:04 PM
Holst56's Avatar
Default slight knock on start-up
I have a b16a1 and all of a sudden while i was out today, i got back to my car and when i started it up and it made a slight knock and the maintinence light came on for a second but went off and the car runs and sounds the same as usual im just concerned about the knock when i start it up. any ideas on what could be the cause of this problem?
Old Oct 21, 2008 | 03:01 PM
BoSox46GSr's Avatar
Default Re: slight knock on start-up (Holst56)
I have the same thing, wouldn't be terribly worried if I were you. The maintenance light has absolutely nothing to do with this by the way. Do you have a CEL?
Old Oct 21, 2008 | 05:40 PM
mayoforlife2's Avatar
Default Re: slight knock on start-up (BoSox46GSr)
have you checked you oil!? also are you sure its not pinging instead of knocking, maybe your running the wrong gas?
Old Oct 21, 2008 | 10:44 PM
Holst56's Avatar
my oil is fine and its really clean. i was a little desperate and got some wawa unleaded gas and then filled it with premium from shell and it hadnt done that until i had put it in. but the noise did stop eventually. do you think that the switch from regular to premium was what caused it?
Old Oct 22, 2008 | 06:29 AM
AWD Terror's Avatar
Default Re: (Holst56)
Someone correct me if I'm wrong, but shouldn't that motor be running 91 octane?
Yes, your motor will ping like crazy if you put in lower, especially under heavy loads.
Old Oct 22, 2008 | 07:57 AM
Default Re: (AWD Terror)
ya 91 at the lowest but i know all the gas stations here expect wawa have 93 wawa only has 91 here but yes that could deffinatly cause the noise your hearing wouldnt recommend putting wawa gas in it , i use to then i got my car and stopped
Old Oct 22, 2008 | 09:44 AM
AWD Terror's Avatar
Default Re: (mayoforlife2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mayoforlife2 &raquo;</TD></TR><TR><TD CLASS="quote">ya 91 at the lowest but i know all the gas stations here expect wawa have 93 wawa only has 91 here but yes that could deffinatly cause the noise your hearing wouldnt recommend putting wawa gas in it , i use to then i got my car and stopped</TD></TR></TABLE>
LOL. I kept thinking you guys were spelling something wrong (wawa) so I looked it up. First thing off the front page:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.wawa.com/WawaWeb/LocationsGas.aspx &raquo;</TD></TR><TR><TD CLASS="quote">Wawa Gasoline is the finest available... It's 100% guaranteed.
Old Oct 22, 2008 | 03:11 PM
haha no but they do have some wonderful subs
Old Oct 22, 2008 | 03:17 PM
danthemang3's Avatar
haha bump for some bang up toasted subs!
Old Oct 23, 2008 | 10:33 PM
Holst56's Avatar
yea, i dont usually put in shitty gas, i usually put in 93 octane. but thanks, i was a little worried there for a minute. and yes, wawa has bangin subs.... especially toasted! haha
Old Oct 23, 2008 | 10:40 PM
peajay_32's Avatar
use a factory honda oil filter next time , thats your motor building oil pressure
Old Oct 24, 2008 | 06:19 AM
AWD Terror's Avatar
Default Re: (peajay_32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peajay_32 &raquo;</TD></TR><TR><TD CLASS="quote">use a factory honda oil filter next time , thats your motor building oil pressure </TD></TR></TABLE>
No reason to waste your money.
Skitso's CB7
May 3, 2011 03:50 PM
StockDC2
Sep 1, 2009 08:59 PM
NikkosDX
Feb 18, 2009 12:55 PM
keepinitsimple
14
Nov 7, 2004 10:28 PM
an2ny888
Feb 11, 2004 03:54 PM
