Tank size
Old Oct 21, 2008 | 11:47 AM
drSquish's Avatar
Default Tank size
Whats the gas tank size on a USDM 97 Civic DX coupe? I'm curious because I am unable to figure out my gas mileage without running it to the ground.
Old Oct 21, 2008 | 11:50 AM
1990CamaroRS's Avatar
Default Re: Tank size (drSquish)
easiest way to find out fuel mileage is to reset your trip odometer when you fill up, then the next time you fill up, divide the number of miles on the odometer by the number of gallons you filled up with (on your receipt)
Old Oct 21, 2008 | 11:52 AM
drSquish's Avatar
25mpg for a built 2.0L LS VTEC
Old Oct 21, 2008 | 11:56 AM
EJ8_Enthusiast's Avatar
11.9 or 12.9 I think (gallons)
do as camero says - fill up all the way, reset trip meter, and next time you get gas fill up all the way again (try to use same pump and station) then do the division.
I get ~ 31 city 1.6 y8 stock
Old Oct 21, 2008 | 11:59 AM
drSquish's Avatar
Default Re: (EJ8_Enthusiast)
thanks guys
Old Oct 21, 2008 | 12:21 PM
turbojdmhatch's Avatar
Default Re: (drSquish)
im pretty sure its an 11.9g tank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">25mpg for a built 2.0L LS VTEC </TD></TR></TABLE>
your super
Old Oct 21, 2008 | 11:45 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
All '96-'00 Civics have 11.9 gallon tanks.
IIRC, all '92-'95 Civics have 11.9 except for (I think) the CX and VX, which have 10 gallon tanks.
That has nothing to do with finding out your fuel economy though.
You can figure out the gas mileage this way. The size of your tank has nothing to do with your fuel economy (save for the weight of a larger tank, but anyway...).
1 - Fill your tank ALL the way up. Reset your tripometer before you leave the gas station.
2 - Drive.
3 - Whenever you decide to get gas next (it does NOT have to be on E), fill the tank ALL the way up again.
4 - Have the pump print the receipt for you. Write the mileage from the tripometer on the receipt.
5 - Rest your tripometer before you leave the gas station.
6 - Drive.
Whenever you get a chance (even at the gas station), do this:
MILES DRIVEN / GALLONS USED = GAS MILEAGE
So if you drove 320 miles and used 9.5 gallons:
320 / 9.5 = 33.68 mpg
Remember, this information will be on the pump and/or receipt and on the tripometer.
You can also keep track of this on gassavers.org
SQ is the SQUAD
Welding / Fabrication
Feb 16, 2011 09:59 PM
bairdc3
Honda Civic (2001 - 2005)
Jun 28, 2008 10:29 AM
HCJDM1
Apr 4, 2007 01:02 PM
type Gendy
Mar 10, 2005 11:31 AM
Hatch It
Nov 8, 2004 08:47 AM
