Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission or clutch problem??
Old Oct 21, 2008 | 08:50 AM
quick84's Avatar
Default Transmission or clutch problem??
Hello. So te other day I'm driving and it felt as if the clutch was not releasing all the way. The engine would rev I could see the rpms go up on the tac, but the car did not accelerate. As I kept driving it got worse. I came to a complete stop and the car would drive. No matter what gear I put it in the engine would just rev. I turned the car off and let it sit for awhile. After about 30 min I turned it back on and it worked without a problem. I just got a new clutch and it has a little over 1k miles on it. Does anyone know what the cause could be and how I can fix it or should I just take it back to the shop that did the clutch
Old Oct 21, 2008 | 08:09 PM
H22tuner415's Avatar
i dont know wats da deal wit da h tranny....my tranny went out within a year..im on my 2nd lsd tranny went through 2 stock clutches already giving me a headache anyone knows wats up????
Old Oct 22, 2008 | 10:04 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Transmission or clutch problem?? (quick84)
first things first....fix your spelling so you attract intelligent people to answer your questions.
Second, you need to tell us if it's a cable or hydraulic trans?
Old Oct 22, 2008 | 10:13 AM
Default Re: Transmission or clutch problem?? (Richard Noggin)
okay its a hydraulic trans. drives well when its cold, but when it gets hot it makes a funny noise. changed out the oem clutch replaced it with a new one it was okay for a couple of months but the problem came back again. thanks.........
Old Oct 22, 2008 | 10:27 AM
Default Re: Transmission or clutch problem?? (H22tuner415)
I'm wondering at this point if it's not a problem with a rear oil seal leak, a possibility that the trans has a problem, or if you have a clutch that is hanging up because the disc is bent or something like that....
does it make the noise ALL of the time when it's warmed up...I mean like, constantly, or only when you depress the pedal?
Old Oct 24, 2008 | 07:13 AM
the problem happens only when im in gear.
Old Dec 14, 2008 | 09:14 PM
yes when the tranny is nice and hot it starts to make the noise...
TruenoMike14
Oct 22, 2013 11:36 PM
quick84
Oct 22, 2008 06:39 PM
jnichols
Aug 31, 2007 12:46 AM
EFing8
15
Sep 23, 2003 06:24 PM
ijjz
Apr 14, 2003 06:08 PM
