Anti-squeal vs caliper pin lube
The counter man at a local parts house told me that I can use anti-squeal compound (used between pads and shims) to lube the caliper pins on the front of my CR-V. Doesn't the anti-squeal compoung set up partially, making it more of a bonding agent than a lubricant?
Anti-seize is not for that application and that is strongly not recommended for use on the sliders. A little on the bolt threads yes but just a little and never on the sliders or any moving part.
OK. Thanks, again, for the reply. I'll head for the parts store (a different one, this time) and get some hi-temp grease made for use on the slider pins. I'm glad I asked! I've got to do the front brakes on the front of my truck, next. I'll be ready for it, now.
they make a lube specifically for brake slides....Its called SIL-GLIDE , they sell it in little tubes at the register or big *** tubes in the back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">That stuff for some reason is hard to find. Most AP stores don't have it, I have being looking for it myself.</TD></TR></TABLE>
they sell this stuff everywhere, sometimes its gotta slightly different name....all the auto stores around here have little packets at the register they try to get you to buy anytime you buy anything brake related
but heres a link anyways
http://www.napaonline.com/Mast...Based
I picked up a 4 oz. bottle of brake system lube that specifically states, on the bottle, that it's to be used on caliper slide pins (among other brake components). It has an application brush in the bottle. Thank you very much for the advice. I imagine that it saved me from having to do the job all over, again.
