My sunroof won't close!
Old Oct 21, 2008 | 08:39 AM
jbiggsSE's Avatar
Default My sunroof won't close!
I've got a 4Dr 2000 Accord w/ a sunroof (I think the dealer added it), and it's been working great for the last 8 years, but all of a sudden it decided it didn't want to close any more. I live in a small town in the middle of no where (college), and it seems that the majority of car places around here only deal w/ oil changes and shocks. Any ideas how I can fix the roof so it'll close? It makes a clicking sound when I push the button, like it normally would do, but then nothing happens. Let me know if you need any more info to help diagnose the problem. Thanksssss
Old Oct 21, 2008 | 08:47 AM
P_Adams's Avatar
Default Re: My sunroof won't close! (jbiggsSE)
If it is a Factory installed unit (I've never seen an aftermarket unit in/on a Honda), there should be an emergency crank mechanism. On Honda's I've owned it was located above a plastic plug on the headlines (to the rear of the moonroof)
2000 you say, let me do some diging.
P
Old Oct 21, 2008 | 08:50 AM
P_Adams's Avatar
Yeh, Honda shows it in this illustration:
http://www.hondaautomotivepart...INING
Just above the rear passanger's head.
let's see what else I can find
P
... and here's the illustration of the mechanism. Particular attention to number 22, the drive assembly. This is where the drive motor mounts, and the plug on the headline lines up with this. I can't find an illustration of a crank handle for this, but something commonly available MIGHT work
http://www.hondaautomotivepart...82%29
Modified by P_Adams at 12:55 PM 10/21/2008
Old Oct 21, 2008 | 09:05 AM
jbiggsSE's Avatar
You're awesome! Thankssssss so much, so I basically pull back the headliner and I should be able to manually crank it ?
Old Oct 21, 2008 | 09:16 AM
P_Adams's Avatar
Default Re: (jbiggsSE)
If it is a factory unit, toy will find a small (1.25") plastic plug on the headliner just above the rear passanger's head(s).
Pop that plug out and you should have access to the mechanism to manually close the sunroof.
If it IS an aftermarket sunroof as you suspected, you'd most likely have to rummage around to find where they sequestered to drive motor and go from there.
P
there should be no need to lower the headliner unless something totally unforseen has happened.
P
Old Oct 21, 2008 | 02:17 PM
jbiggsSE's Avatar
Alright, great, thanks. I took a look, and I wasn't able to find a plug, so I'm gonna assume it was an aftermarket install. Hopefully it doesn't rain tonight
Thanks a bunch
Old Oct 21, 2008 | 04:21 PM
P_Adams's Avatar
Sorry I can't be more helpful, but without some familiarity with the unit you've got - i'd be nothing more than a hinderance.
Does this unit appear self-contained, or does it utilize a remote mounted drive motor? Did you hear the motor above your head, or was in the the rear - possibly the trunk? Some aftermarket units (and some older domestic models) mount it there.
P
Old Oct 21, 2008 | 04:24 PM
jbiggsSE's Avatar
It seems to be self contained... the 'clicking' I hear, which I've always heard when I push the button, is right above the driver's seat. I'm gonna try and tear into it tomorrow when I've got some free time and see what I can find.
Old Oct 23, 2008 | 08:30 AM
jbiggsSE's Avatar
Had an appointment to take it in to get fixed at some dealership, got in the car, just for fun I tried closing it... it WORKEDDDDD, WOOOO. It was supposed to rain tonight too, I got soooooooo lucky. Haha, Thanks for the help !
Old Oct 23, 2008 | 08:40 AM
P_Adams's Avatar
I've often maintained my Honda's will fix themselves if given enough time :-) .
I guess yours just wasn't ready to deal with a rain soaked interior.
At least now you've got time to assess the situation without being under the gun
Good Luck
P
Old Oct 23, 2008 | 09:12 PM
jwicecold's Avatar
LOL hondas always fix themselves some how, but if you dont find the problem while its there it could be a pain to fix when it no longer does the problem or eventually come back... like usual.. ;-)
Old Nov 27, 2013 | 01:29 PM
DMCMotorCompany's Avatar
I had a 2003 Honda Accord EX 4DR and the sunroof would open but would not close using the close button. Had to use the tilt up switch button to close it. After doing the research, i was able to find a TSB with a repair for the problem which seems to be common. It calls for the replacement of "Moonroof Limit Switch" but Honda Dealer had no such part listed so did some more research and found the part number and they listed it as "Sunroof Tilter Switch". Had to drop the rear of the sunroof as the part was located right behind the rear interior light and replacing the part resolved the problem. Part is #18 on the sunroof assembly diagram.
Old Oct 22, 2014 | 04:56 PM
PhaedraAli's Avatar
My sons 2006 accord sunroof won't open. Was working fine, no issues at all. Had to have his brake switch replaced yesterday because brake lights were flickering and sometimes not working. Those work fine, but now no sunroof function. Not making any noise at all, like a motor trying or any clicking noises. Could it be a fuse? He is two hours away at college...
Old Oct 25, 2014 | 06:14 AM
Lost Again's Avatar
Not really the place for a 2006 but anyway.
Check #28 20amp fuse in the under dash panel. If good, you will need to do some testing - have a volt meter or test light?
Peter Bennetts
Honda CR-V & Element
Feb 24, 2017 09:06 AM
Javaair
Sep 2, 2010 09:41 AM
GS'D YA
Jun 22, 2009 09:22 PM
jfernandez1977
Feb 3, 2008 06:32 AM
