those with 205 50 15 tires
just wondering... did you experience any fender rubbing? now that my car is pretty much dumped.. im wondering if i will get fender rub with the 205 50 15 tires compared to stock 195 55 15s.
yeah, but atleast I dont have 'other things' rubbing on the ground. Really though, I would like to go lower, and I will when my car becomes more intended for track use, but right now for the street and driven daily this setup works great. Have a good one, enjoy
any lower and you will begin tohurt handling.
too low and 205/50/15 will rub the inside at full turn and the fender liner durning bumps.
your nuts dude, how is a smaller tire gonna rub?
none that i can hear or see . . . put it that way , I have had the wheels off many times and no signs of rubbing
Thanks teken. Full lock, stock wheels, stock ride height will rub the inside enough to run off the under coating.
I never said rub bad enough to hurt anything but they will rub. it isn't trie height that is a problem it is tire width.
I could probab;ly get a 195/55/15 to run at full lock at an auto-x too.
Teken: 205-50-15 is wider !!! Not narrower, than stock...
at the same time.. since its "50" and not "55", it wont sit as high and thus, the tire will be skinnier "height" wise... also givin it more leeway to turn.
I will put it this way. I have owned a 1994 GSR, a different 1994 GSR, a 2000 Type-R and currenty a 1998 Type-R. I have run them all with 205/50/15, some at stock height some lowered as much as 1.5". THey ALL (yes, including the stock hieght cars) rub . I do race my car and auto-x. Turning a "full lock" (wheel turned till it doesn't turn anymore) 180 degree turn will rub on any integra running 205's. It is a mile rub and nothing to worry about but will rub a small spot on the inner fender. I have even had a 195/55 rub on my 2000 Type-R at an auto-x.
Is a 205/50 a bad size tire? No like I said despite mild running I ran them on all 4 of my intagres. Will they rub? All depends on how sharp the turns the original poster takes.
Note: 205/50/15 do not rub on anything while driving in a straight line or making normal (90 degree) turns. So depending on what other posters are meaning, no 205's do not inherently rub but can due to driving conditions.
I've have never seen or heard any rubbing with my tires, and I'm lowered nearly 2" all around.
I will check the inner fenderwells again when I do some work on my car next week.
[Modified by PatrickGSR94, 9:48 AM 7/30/2002]
I have 205/50/15 tires on my car now and I have ProKit springs and I don't experience any rubbing. I've made turns full lock going forwards and backwards and nothing. I would recommend this tire size because you get a wider footprint on the ground.
I have 205 50 15,and my car is slammed with H&R race springs,it does rub if the tire is turned 180 degrees,I noticed when I was pulling out of my friends driveway and the wheel was all the way cut and I could hear it rubbing.
Let me take your car for a spin and show you what I mean by a full lock turn rubbing.
I have 205/50-15 tires on my teggy with all stock suspension. People say they don't rub, but I think they just haven't turn quick enough. When I make fast turns (I really mean fast and quick), they would rub. They would rub and I would scare, then back off.
I think if I have a better sway bar and stiffer spring, it would save my tires a bit.
I didn't hear or feel any rubbing last time i went to the track. I guess autocross might be a tad more demanding because of the severity in changes of direction...
