stock B-series sleeves a little off-centre in aluminium jacket?
Old Oct 21, 2008 | 06:52 AM
hondaapi's Avatar
Default stock B-series sleeves a little off-centre in aluminium jacket?
Has somebody ever noticed if some stock B-series sleeves are a little "off-centre" in the aluminium jacket?
I mean that if you look onto the deck that the iron sleeve is a little thicker on the one site than on the opposite?
For example 1.7mm at 12 o´clock and 3mm at 6 o´clock ...
Thanks
Old Oct 21, 2008 | 07:16 AM
Running925's Avatar
Default Re: stock B-series sleeves a little off-centre in aluminium jacket? (hondaapi)
i've seen this when the machine shop bore's .020 over and does a shitty job!
Old Oct 21, 2008 | 08:30 AM
hondaapi's Avatar
Default Re: stock B-series sleeves a little off-centre in aluminium jacket? (Running925)
Ok, I understand. You mean the 0.02"overbore trough the cylinder was off-centre from the middle axis of the sleeve?
Are there any experiences in how far this is critical?
Old Oct 21, 2008 | 09:44 AM
LastGenEK's Avatar
Can you post a Pic so we can check it out?
Old Oct 21, 2008 | 10:26 AM
hondaapi's Avatar
Default Re: stock B-series sleeves a little off-centre in aluminium jacket? (LastGenEK)
Here´s the picture. To be truth this is the first (built roundabout 150blocks)time I noticed something like this...maybe I never checked it before...
Old Oct 22, 2008 | 03:15 PM
RC000E's Avatar
It almost appears as if the cylinder is out of round. It's certainly not normal, at least in all the motors I've build, I've never seen it. It may happen to some small degree, but none that noticeable to the naked eye.
TekBuDDy
Transmission & Drivetrain
Nov 11, 2018 11:20 AM
BoostnEK6206
Jan 31, 2008 01:14 PM
boostincoupe
Jan 10, 2008 01:01 PM
DJslepton
Jul 8, 2006 10:38 AM
