Need Help Transmission Problem
Hey guys I have a b20 with an ls hydro trans. Well when I first got it it was smooth all gears, then it started not letting me in 1st...like a wall was there. Then I found a way to get it in and then on the way to PA the other weekend it wouldnt let it go in again...at all. So I found a way to get it in then on the way back from PA 2nd started to grind. So I drove around till I got to my dads to check the fluid, but on the way there it got to the point where if I was in neutral...i had no play to the left (towards 1st and 2nd) but did however have it to the right. We replaced the linkage and still no help. 3rd 4th 5th and reverse are still there but I cant go to 1st or 2nd because it wont let me over. If the trans did go out, shouldnt I still have some kind of play in neutral?? Let me know. Also accepting offers for trans also looking for ls or b16.
ALL HELP IS APPRECIATED!!!!
THANKS ALOT
THANKS ALOT
From: gravity rides everything...everything will fall, se GA/ne FL
your LS trans has a problem inside. it would need to be opened up. i have a good condition GSR trans. located in GA. pm me if you're interested.
