Suspension & Brakes Theory, alignment, spring rates....
Issues Installing front lower tie bar
Old Oct 20, 2008 | 01:37 PM
Lokeyo's Avatar
Default Issues Installing front lower tie bar
here is the issues I'm having the bolt on the passenger side for the LCA will come off easily but the one on the driver side will come off about 1 centimeter after that it will move a little and then make a claking noise I try an air rachet, Impact Wrench and a braker bar with a cheater pipe and got nothing use a lot of WD40 no go on the bolt that came out there is more than 1 inch thread so I'm confuse don't know what else to do i really don't want to break the bolt so I screw it back in no problems any sugestions on what i can I do to get it off
Old Oct 20, 2008 | 05:47 PM
alphalanos's Avatar
Default Re: Issues Installing front lower tie bar (Lokeyo)
You might need to use a screwdriver or something and tap it out with a hammer. TAP it dont smash it, you might need to unscrew it and keep tapping with the hammer. some of the suspension bolts only have threading at the ends.
Old Oct 20, 2008 | 06:21 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Issues Installing front lower tie bar (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">You might need to use a screwdriver or something and tap it out with a hammer. TAP it dont smash it, you might need to unscrew it and keep tapping with the hammer. some of the suspension bolts only have threading at the ends.</TD></TR></TABLE> Mostly, I'd also chalk it up to god saying don't bother with doing that install.
Old Oct 21, 2008 | 05:04 PM
alphalanos's Avatar
Default Re: Issues Installing front lower tie bar (***$nyper)
LOL yeah I realized that installing an H brace was dumb when I went to change my oil for the first time. Such a pain now.
kornerk12
Apr 15, 2007 07:37 PM
dukers
Nov 14, 2004 12:36 AM
type Gendy
22
Apr 1, 2004 11:29 AM
Liquidgsr
Mar 25, 2004 01:32 PM
ShiftDown
Sep 20, 2002 11:34 AM
