Gauge cluster lights not working
Old Oct 20, 2008 | 12:47 PM
Antonio_P.R's Avatar
Default Gauge cluster lights not working
Checked fuse and its good.. I ran a 12v wire 2 the cluster and the lights work and the dimer works 2. now by me doing that am i by passing the dimer ? Is the dimer my problem ?
Old Oct 20, 2008 | 01:58 PM
Default Re: Gauge cluster lights not working (Antonio_P.R)
Anyone ? please
Old Oct 20, 2008 | 10:34 PM
Icaras's Avatar
Okay I'll take a shot at this. Have you tried disconnecting the connectors, one at a time, behind the instrument cluster. Then turn on your lights and see if your backlights come on. Start first with a C711 connector which is dimmer circuit for your backlighting. Purchase a few fuses first before starting this adventure.
Hope this helps in someway. Good Hunting.
Old Oct 20, 2008 | 11:08 PM
Shermanef9's Avatar
Check the relay right above the gas pedal... its hanging on a bracket.
Old Oct 21, 2008 | 07:55 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Shermanef9)
I have heard off and on that the dimmer switch is the major cause for most of the headaches associated with the dash lights. I would start there and test the dimmer switch to see if anything is wrong with it resistance wise.
after that, i would think the combo switch on the steering column would be the next most likely cause, but relays are always good things to check.
Old Oct 21, 2008 | 09:52 AM
Default Re: (sanimalp)
Thanks evryone. It was the dimer !
mynameisMUDD
12
Jan 16, 2010 02:10 PM
swtch7
Sep 4, 2008 04:22 AM
kaychi
Apr 2, 2007 10:03 AM
Jay.D.Em!
Apr 17, 2006 07:17 PM
92'si
Nov 12, 2005 09:07 AM
