Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 CRV Shift Map?
Old Oct 20, 2008 | 12:00 PM
e1337one's Avatar
Default 2000 CRV Shift Map?
I would like to be able to hold the transmission in 1st gear past 5,000rpm.. is this possible?
Old Oct 21, 2008 | 07:21 AM
Ross 2.0's Avatar
In a Junkyard near you.
Hold it in gear with the shifter. But it makes no power up there.
Old Oct 21, 2008 | 07:30 AM
e1337one's Avatar
Default Re: (Ross 2.0)
it makes more power up there than from 1500 - 3000 in 2nd..
you can't hold it in gear with the shifter, it will not manually shift into 1st gear. if i drop it before it gets to 5000rpm it shifts into second..
the shifter will only shift it into second.. if i start off with it shifted all of the way down it starts in second...
fyi - it isnt a stock b20z2, and it isnt in a crv
Modified by e1337one at 9:52 AM 10/21/2008
Fitz Williams
Sep 8, 2015 03:57 PM
jumpin4abeat
Jun 30, 2011 06:55 AM
konvikt
Jan 20, 2007 08:01 PM
alexisthemovie
Dec 30, 2006 03:33 AM
