no mph's and no v-tec help
Old Oct 20, 2008 | 11:56 AM
90hatchblack's Avatar
Default no mph's and no v-tec help
so i changed the clutch in this guys 00 type r and i test drove it and it cracked v tec and the mph gauge worked and the odometer worked and now he says they dont work idk whats going on oh and he has this stupind *** switch in his car for the alternator so he can turn it off or on while hes "racing" could that be it? n e ways can someone help me out here i checked all my grounds and everything and its all good could it be a fuse or a relay lmk please
Old Oct 20, 2008 | 12:00 PM
walker111's Avatar
Default Re: no mph's and no v-tec help (90hatchblack)
vss
Old Oct 20, 2008 | 12:02 PM
Default Re: no mph's and no v-tec help (walker111)
what is dat explain plz i am simple
Old Oct 20, 2008 | 12:04 PM
oh its the speed o ok well does that explain the no v-tec engagement
Old Oct 20, 2008 | 01:12 PM
99SlammedCivic's Avatar
Snipper Snapper
Vehicle speed sensor... VTEC will not engage if it is bad.. its an easy fix !
It is on the top of the transmission if u look down from the tb area...
Good luck
Old Oct 20, 2008 | 01:16 PM
Default Re: no mph's and no v-tec help (99SlammedCivic)
ok where can i get one for cheap
Old Oct 20, 2008 | 01:22 PM
Snipper Snapper
https://honda-tech.com
Old Oct 20, 2008 | 01:48 PM
Bbasso's Avatar
I have a spare VSS sitting in the garage, make me an offer.
I have no clue if it works or doesn't...
Old Oct 20, 2008 | 02:38 PM
Jay D. Em's Avatar
Look at it before you buy a new one... I just changed my clutch and the same thing happened to me. Took the VSS back out and saw that it was really corroded so I cleaned it off and it's good a new.
Old Oct 21, 2008 | 03:20 AM
walker111's Avatar
Default Re: (Jay D. Em)
It might just not be plugged in all the way.
Old Oct 21, 2008 | 04:50 AM
Dave_B's Avatar
Un plug... check the connectors for corrosion... FIRST.
Then if you deem it's bad, then replace.
Old Oct 21, 2008 | 08:14 AM
Girlzcn2's Avatar
check the fuse.
Old Oct 21, 2008 | 02:13 PM
robfrmny21's Avatar
sounds like fuse
Old Oct 21, 2008 | 03:09 PM
crx(gator)'s Avatar
Default Re: (robfrmny21)
y0 i b3 cracKa lack9n s0m3 of Dat Der3 vTACKKKKKKKK s0n. b8t 4 shiZzlY on Da RiZZl3, knawwwM3an?
hondaEg_808
May 17, 2010 02:12 PM
mrpaccmann
Jan 13, 2010 05:29 AM
young geezer
May 21, 2009 06:20 PM
lemongreenhatch
Jun 12, 2004 08:15 PM
SOJAMR1
Mar 23, 2003 03:53 PM
