FS: 93 Integra-4 Door-5 Speed
I picked up a new project so this one has to go. Bought it with bad motor, bought a motor and put it in. Currently needs some finishing touches (exhaust leak/radiator hose/a few electrical connections) but as of right now the car will start and run. Has new battery, oem clutch, t-belt, water pump, accesory belts. Windshield is cracked at the very bottom (i would pass for inspection, not in your view) Passenger rear window more than likely needs a switch (wont roll up) Hood as hood pins and no hood latch. Interior is very clean with only some goo stained on passenger front seat and door panel. I probably forgot tons of stuff so feel free to ask questions.
Car also has civic hubcaps but you can have the trim rings if you want. Tint has been pulled off, the glue is still there.
Roughly 146k on car, a few k more on motor. Clean MO title
<FONT COLOR=""Lime"">$1600 Firm w/ everything in tip top shape
</FONT>
<FONT COLOR=""lime"">$1300 As is</FONT>
</FONT>
