k20Z1 eg supercharge??
Old Oct 19, 2008 | 06:37 PM
FUNCTIONAL-EG's Avatar
Default k20Z1 eg supercharge??
I have a k20Z1 currently being swapped into my eg coupe , I'm gonna be workin my way into the autocross scene and I was wondering if I should use an 06+ supercharger or should I swap my bottom for a k24 ?? thx. guys any info is well appreciated
Old Oct 20, 2008 | 05:58 AM
Jaker's Avatar
Default Re: k20Z1 eg supercharge?? (FUNCTIONAL-EG)
With the swap, you'll most likely end up in Street Modified. This class has a displacement based weight limit. FWD are 1550 plus 125lbs per litre. If you run the 2.4 block, you'll have a minimum weight of 1850lbs. If you run the 2.0 with the SC, your minimum weight goes up to 1975. This is because forced induction "adds" 1.4 litres to your displacement. For 2009, there will be a 200lb weight limit reduction for all Street Modified cars running 275 or narrower tires on all 4 corners. This will permit you to get down to 1650 for the 2.4 and 1775 for the 2.0 with the SC.
Old Oct 20, 2008 | 09:44 AM
Default Re: k20Z1 eg supercharge?? (Jaker)
wow , I see I have 2 do a little more research then I've already done , thx. jaker
Roy Leyva
May 9, 2017 08:15 PM
Steeve_Civic
Nov 13, 2011 06:22 AM
H.crx-si
Feb 12, 2005 08:12 AM
