vss ?
Old Oct 19, 2008 | 04:06 PM
turbo-crx's Avatar
Default vss ?
My speedo does not work and it is plugged into the tranny. How can it stop working of its cable driven? Also, would it have an affect on how the cars runs if the speedo didn't work?
Old Oct 19, 2008 | 04:52 PM
IndySporty's Avatar
Default Re: vss ? (turbo-crx)
check where it goes into the cluster, sometimes it can be disconnected enough to not work but still looked plugged in. also try pulling it out of the tranny and hooking a VSR drill to it and running the drill, your speedo should go up to like 70MPH (try it both in forward and reverse) if the drill doesn't make your speedo move then either the cable is broken or it's disconnected, or your cluster has stopped working properly. And yes the car will act up sometimes from having the speedometer stop working, the ECU uses the signal from the speedo.
Old Oct 19, 2008 | 06:17 PM
turbo-crx's Avatar
Default Re: vss ? (IndySporty)
How do I use the vsr drill method? I'm not sure how to do it or what to hook the drill to.
Old Oct 20, 2008 | 08:45 AM
turbo-crx's Avatar
anybody else have suggestions?
Old Oct 20, 2008 | 11:52 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
At the transmission,pull the inside completely out of the housing:
The entire inner cable should be 34 3/4" long..
If not,it is broken..
If the cable is in one piece,Grease it up and stick it back in the housing:
Old Oct 20, 2008 | 12:05 PM
turbo-crx's Avatar
Default Re: vss ? (88DXCRX)
cool thanks man.
88EFsedan2
Feb 2, 2012 08:24 AM
Gawear
Jun 19, 2010 08:22 AM
EF9 JAMS!!!
Mar 26, 2006 01:27 PM
coot_er
Oct 2, 2005 10:33 PM
loid
Jul 26, 2004 08:33 AM
