HELP! 91 civic hatchback si B SERIES SWAP QUESTION
Old Oct 19, 2008 | 09:12 AM
wing.jai's Avatar
Default HELP! 91 civic hatchback si B SERIES SWAP QUESTION
got what i needed to know. thanks for the info guys.
Modified by wing.jai at 11:47 PM 10/19/2008
Old Oct 19, 2008 | 09:29 AM
89s1's Avatar
Default Re: HELP! 91 civic hatchback si B SERIES SWAP QUESTION (wing.jai)
You will need aftermarket mounts.
The mount that they are referring to is the actual cast mount bracket that bolts to the block as some are not the right shape to allow the engine to go into our chassis.
If you're in this swap to spend as little as possible it is going to be a nightmare. Open up your wallet and do things right.
Old Oct 19, 2008 | 10:01 AM
wing.jai's Avatar
understood.
Old Oct 19, 2008 | 10:34 PM
wing.jai's Avatar
TTT
Old Oct 19, 2008 | 10:40 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wing.jai &raquo;</TD></TR><TR><TD CLASS="quote">understood.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wing.jai &raquo;</TD></TR><TR><TD CLASS="quote">so bacially you cant use the 90-93 motor mount right? </TD></TR></TABLE>
Old Oct 19, 2008 | 10:47 PM
wing.jai's Avatar
Default Re: HELP! 91 civic hatchback si B SERIES SWAP QUESTION (89s1)
jst wanted to double check but got the info i need from a fellow member thanks
sikciv666
Jul 22, 2007 11:40 AM
aragorn1023
14
Apr 11, 2007 10:14 AM
Bseries!EF!hatch
11
Jun 13, 2006 12:53 PM
error
Aug 11, 2005 05:12 PM
89dohcEF
Oct 29, 2003 01:03 PM
