Dual-din head unit with removable face?
Old Oct 19, 2008 | 12:53 AM
alacard's Avatar
Default Dual-din head unit with removable face?
Are there any dual-din head units like this: http://www.alpine-usa.com/US-e...-W505
that have removable faces?? I really need a new head unit but the last thing I want to do is spend 800+ on a new head unit only to have someone break a window and yank it right out. Any such head unit?
Old Oct 19, 2008 | 05:21 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dual-din head unit with removable face? (alacard)
As far as I know, nothing like that exists.
Old Oct 19, 2008 | 09:52 AM
alacard's Avatar
Default Re: Dual-din head unit with removable face? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know, nothing like that exists.</TD></TR></TABLE>
Well what does everyone do for security with those things?
Old Oct 19, 2008 | 09:59 AM
fcm's Avatar
fcm
Old Fart
A "dummy" face plate made from the face of a stock HU. 94
Old Oct 19, 2008 | 10:31 AM
alacard's Avatar
Default Re: Dual-din head unit with removable face? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">A "dummy" face plate made from the face of a stock HU. 94</TD></TR></TABLE>
Do you think a radio block off plate would work? I don't know...it seems like the face of the head unit would stick out too far to fit a block off plate or a dummy face.
Old Oct 19, 2008 | 12:52 PM
fcm's Avatar
fcm
Old Fart
Once you peel the face off the stock HU and grind off anything on the back and make the face as thin as possible and recess the aftermarket HU a little the "dummy" plate will look like a stock HU, I have done it lots of times.
A block off plate is not much better then nothing at all as you must be hiding something.
I did have a customer who wanted me to recess the HU, [single din] a little so he could install a block off plate that he had "embossed" a "pix" of a stock cass. deck to and glued some ***** to, that was pretty good, looked real until you looked real close. 94
Old Oct 19, 2008 | 01:22 PM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Once you peel the face off the stock HU and grind off anything on the back and make the face as thin as possible and recess the aftermarket HU a little the "dummy" plate will look like a stock HU, I have done it lots of times.
I did have a customer who wanted me to recess the HU, [single din] a little so he could install a block off plate that he had "embossed" a "pix" of a stock cass. deck to and glued some ***** to, that was pretty good, looked real until you looked real close. 94 </TD></TR></TABLE>
How do you recess the headunit? I thought they were pretty fixed to a certain position?
Old Oct 19, 2008 | 01:43 PM
alacard's Avatar
Also while we are talking about it, do you have any pictures of this?
Old Oct 19, 2008 | 01:59 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">
How do you recess the headunit? I thought they were pretty fixed to a certain position?</TD></TR></TABLE>
If the unit is ISO mounted, you can usually change the mounting depths with relative ease.
Old Oct 19, 2008 | 04:44 PM
doggworld1233's Avatar
JVC 810 has a removal face
Old Oct 19, 2008 | 10:50 PM
alacard's Avatar
Default Re: (doggworld1233)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">JVC 810 has a removal face </TD></TR></TABLE>
Sweet, thanks man. Any reviews on this head unit?
Old Oct 20, 2008 | 05:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: (alacard)
Sorry, no pix. 94
Old Oct 21, 2008 | 10:12 AM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, no pix. 94</TD></TR></TABLE>
It's cool, thanks though.
So in the event that I bought that unit:
http://www.amazon.com/JVC-KW-A...r=1-6
would I be able to recess it a little in case it doesn't sit very flush with my dash? I read some comments people had about it not sitting extremely flush due to the removable face.
Old Oct 21, 2008 | 03:56 PM
sil04ver's Avatar
JVC and I beleive Eclipse make double din NAV units w/ detachable faces.
Old Oct 21, 2008 | 09:17 PM
alacard's Avatar
Default Re: (sil04ver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil04ver &raquo;</TD></TR><TR><TD CLASS="quote">JVC and I beleive Eclipse make double din NAV units w/ detachable faces.</TD></TR></TABLE>
Alright, cool man. Thanks.
Does anyone know if I would be able to recess the JVC a little in case it doesn't sit very flush with my dash? I read some reviews people had about it not sitting extremely flush due to the removable face.
Old Oct 22, 2008 | 05:11 AM
fcm's Avatar
fcm
Old Fart
Does anyone know if I would be able to recess the JVC a little in case it doesn't sit very flush with my dash? I read some reviews people had about it not sitting extremely flush due to the removable face.</TD></TR></TABLE> MM&Y of car? 94
Old Oct 22, 2008 | 10:05 PM
alacard's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> MM&Y of car? 94</TD></TR></TABLE>
Sorry , 99 civic hatch
Old Oct 23, 2008 | 04:58 AM
fcm's Avatar
fcm
Old Fart
It is an "ISO" mount so it is easy to recess the HU and you can do the "custom" mounting on a bench as the whole assembly, [holding HU] comes out of the dash... http://www.installdr.com/Insta...5.pdf 94
Old Oct 23, 2008 | 09:33 PM
alacard's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">It is an "ISO" mount so it is easy to recess the HU and you can do the "custom" mounting on a bench as the whole assembly, [holding HU] comes out of the dash... http://www.installdr.com/Insta...5.pdf 94
Alright, cool. Thanks for the info
Old Oct 29, 2008 | 07:50 AM
JDMCRX's Avatar
Just get a piece of 1/8" Plastic from local audio shops and trim it to fit the dimentions of ur openeing. I put my radio back 1/4" build the piece. Go get a old dead radio take it all apart. Take the face and buttons and sand them down and glue them on and then u got ur dummy plate.
What dummy wants a stock radio is a dummy LOL.
Old Nov 5, 2008 | 07:44 PM
blkSi724's Avatar
that alpine 505 is nice the face is not removable but its a quality headunit
i bought a 205 for my civic and like the 505 better but it was on backorder
Demon86RJC
Aug 11, 2009 08:13 PM
Blazin Si
Audio / Security / Video
Nov 25, 2008 04:36 PM
Pippen_001
Oct 28, 2008 12:00 PM
Natural Aspirations
51
Sep 12, 2008 06:06 AM
