FlywheelS, flywheels, FlywheelS
GUYS, I need some infromation, and I am hoping, after I searched through all the threads that I could and found out what info I could, that you guys might be able to help me out.
I am taking my car in for service, it needs a new clutch, some other transmission work and timing belt service. I am pretty much set on the clutch that i am going to get(exedy organic) but at the time that i do all this i want to throw in a lightened flywheel. Now I've talked to some friends in the industry and they have told me that the lighter the flywheel gets the more you will have to slip the clutch in order to get a smooth pull on the tarnsmission, now i think the stock flywheel in a GSR is around 20 pounds(cloud be more) or so, i have heard that the ITR flywheel is around fourteen fifteen pounds, and the aftermarket flywheels start around 8.5 and go up.
So here is where I need your guys feedback. I was planning on geting an EXEDY chromoly flywheel as well as the clutch, but it only weighs in at 10 pounds. I think for a daily driver that that is too light, are there any manufacturer's that make a lightened flywheel in the twelve and up range. I would prefer Chromoly because I am not a big fan of aluminum in a car that can rev up to 8500 rpm. OR if there are any folks out there that took their ITR flywheel out and are looking to unload it send me an im on aol(liveslifewell- my screenname). Any information would be greatly appreciated, the sooner the better because i am dropping my car off on Tuesday, which is tomorrow. Thanks again guys.
Just had a friend put one in his S2000, and he agrees with me. If there is any difference in stop and go driving, then it is minimal...
Jason
where can i find a good price on the TODA unit, i can get the exedy package for $630 and for me that's about my limit maybe another 50 bones but more than likely if it isn't priced comparitively close o the exedy i think i'm gonna go with the exedy.
i have a cm 10 lb in mine and it works great, all the bad things i heard about flywheels seem to have come from people that did not have one. and i drive my car all the time
First of all, the stock GSR flywheel is more like 18lbs, the typeR is more like 14.5lbs and most aftermarket ones start at around 7lbs and go up(to about 10lbs). I have also been looking for a high quality FW with a weight a little less than the R but a little more than 9 or 10lbs. I will probably just go with the R FW as it will have the reliability that I am looking for with a bit more gain in performance. Otherwise I might want to go with a chromoly one from Comptech or Toda. Enjoy
Worth a try...
Jason
My 7.5 lb ClutchMasters flywheel gives me no drivability problems, as long as you know what you're doing with the clutch pedal and shifter. It revs like a champ now, too. The revs climb so fast, it's really amazing. I'm sure a heavier flywheel would yeild slightly better daily manners, but if you're confident in your ability at all, you should have no problem adjusting to a light flywheel.
Good luck with your choice.
i switched up from an itr flywheel to a toda one. the difference is noticeable. it was not as noticeable when i went from stock to itr. make sense? a ~10 lb. flywheel is in my opinion an ideal weight.
Performance? I gained fast reving. great for rev matching. heh. Also heard that every lb of rotational mass u loose like alot more ..but I dont know how that works... I seem too accelerate faster too...dunno if its just wishfull thinkin..anyone back this up?
IntegraMastaz
Dec 13, 2005 05:26 AM
