Increasing camber, new alignment?
Hey sup.
I have a 99Si, Skunk2 camber kit, thinking of going back to oem.
Car is dropped about 2" - 2.5"
Will i have to get an alignment after i change the uca?
Yes, absolutely. The toe changes any time camber is changed. If you don't reset the toe after removing the camber kit, the tires will wear unevenly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TotalBalance »</TD></TR><TR><TD CLASS="quote">Yes, you need a new alignment. Whenever you change the setting, you need to get full alignment. Always do height -> camber -> toe order when doing the alignment.</TD></TR></TABLE>
i agree.
either get a lifetime alignment at a place like firestone or invest in your longacre toe measurement plates and camber gauges if youre going to be fooling around with ride height OR camber arms.
i agree.
