Can you unwarp a brake rotor?
Old Jul 29, 2002 | 06:20 AM
BDiddy's Avatar
Default Can you unwarp a brake rotor?
Yes it sounds stupid but Im really curious about this...
I went to VIR at the end of Feb and warped my rotors pretty good I havent had them changed since, but they arent warped anymore. No more shimmy or vibration. I have the Endless CCX pads on there.
It is possible that the daily driving and light braking of the car since the end of Feb have smoothed out the rotors due to the abrasive nature of my pads?
Ive had a couple people drive the car after I got back from VIR and then just last week my friends dad drove it and said it felt much better with the new rotors.
Thought?
Old Jul 29, 2002 | 06:26 AM
pyromaster's Avatar
Default Re: Can you unwarp a brake rotor? (Megatron)
when i warped my 1st set it was only appearant at speeds over 90, so i felt it on the track or occasionally the freeway if i hit 90 and then hit the brakes (which i'd do just to test the rotors) but not with normal street driving. maybe same scenario for you?
Old Jul 29, 2002 | 06:42 AM
Willard's Avatar
you may not have 'warped' the rotors...
http://www.stoptech.com/whitepapers/...otors_myth.htm
Old Jul 29, 2002 | 06:52 AM
Doctor CorteZ's Avatar
Default Re: Can you unwarp a brake rotor? (Willard)
I was looking for that link when you posted it
guess i should be faster Willie ..............
Old Jul 29, 2002 | 06:54 AM
BDiddy's Avatar
Default Re: Can you unwarp a brake rotor? (Doctor CorteZ)
cool. Nice link
Guess my friends dad hasnt kept up in the biz for a while.. he used to race Minis back in the day
Old Jul 30, 2002 | 07:09 AM
Muckman's Avatar
Moderator in Chief
That article was spectacular!
I bedded my stock brake pads again and it fixed my vibration. I did 5 or 6 60-5 stops and 2 100-5 stops. However after I let my car sit in the garage over night and cool off, my brakes now seem to grab less. There is stil alot of pad left (1/3). I immediently felt that I had to push the pedal down more than usual to achieve the same braking force as Im used to.
Does it sound like the bedding was done incorrectly? Or did I just wear out my pads?
Old Jul 30, 2002 | 07:24 AM
owen_the_soyboy's Avatar
Default Re: Can you unwarp a brake rotor? (Muckman)
Hmmm, it sounds like you need to bleed your brake lines. The high temps you just reached by re-bedding your pads may have boiled some of your fluid, which I am guessing has not been bled/replaced in a while if ever. A simple bleed would help you, thats my 2 cents.
dragonkx
13
Jun 29, 2010 07:37 AM
H2290
10
Jul 28, 2006 01:56 PM
onyx00
Sep 16, 2004 11:00 AM
WRXRacer111
Aug 1, 2002 10:58 AM
BDiddy
Jul 8, 2002 07:45 AM
