Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 Accord Sedan Headlight Wiring/Schematic
Old Oct 18, 2008 | 04:30 PM
wekiser's Avatar
Default 2008 Accord Sedan Headlight Wiring/Schematic
Hello!! Could anyone give me or post wiring diagram or schematic for the front headlights? I would like to know how the Daytime Running Lights are wired. Could anyone help???
Old Oct 20, 2008 | 07:54 AM
Ross 2.0's Avatar
In a Junkyard near you.
What are you trying to do with it?
Old Oct 20, 2008 | 08:17 AM
jasonacura91's Avatar
Default Re: 2008 Accord Sedan Headlight Wiring/Schematic (wekiser)
google search
Old Oct 22, 2008 | 06:51 PM
wekiser's Avatar
I am working on an HID retrofit. I am doing the TFX Retrofit (search on Google and you will get a description). I am wanting to use the High Beam function to active the Solenoid on the Bi-Xenon Projector.
Could anyone help?? Thanks!!!
Old Oct 23, 2008 | 06:44 AM
Ross 2.0's Avatar
You can use the normal high/low beam circuits but not the DRL power.
If you wanted to use the high beam circuit to activate the solenoid you would need to disable the DRL system. It doesn't apply a constant voltage from the DRL unit for the lights to operate rather pulses to achieve 8V (not 100% sure on the final voltage).
Pardie
Lighting
Jun 29, 2014 07:46 PM
ITR#974
Mar 28, 2009 05:10 AM
viet_tec
Dec 22, 2007 12:40 AM
Stryker
Sep 24, 2004 05:32 PM
