tires and wheels questions
Old Oct 18, 2008 | 04:17 PM
joeyjoeysee's Avatar
Default tires and wheels questions
hey whats up all. im looking to change my wheel/tire setup. I have a 96 civic coupe. I thinking about goin to a 15 x 6.5 or 7.0 wheel with a 225/50r15 tire. For a drag radial should I go with 6.5 or 7.0 in the front. Also what type of setup should I use in the rear for a dd/track car. thank you
Old Oct 19, 2008 | 01:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tires and wheels questions (joeyjoeysee)
That tire size is MUCH too big for your car and will definitely rub. NOT recommended.
First of all, is your '96 a DX model, or an LX or EX? (Yes, it makes a difference.)
And when you ask about a dd/track car, are you really talking about using the tires at the track, or only on a dragstrip?
Old Oct 19, 2008 | 07:29 PM
Default Re: tires and wheels questions (nsxtasy)
96 ex. wheel setup will only be run during dry periods of the year and will be used at the strip
Old Oct 19, 2008 | 08:50 PM
UncleD's Avatar
A 7 would be better for that tire.
Old Oct 20, 2008 | 01:44 PM
Default Re: tires and wheels questions (clean rice)
alright cool. do u think rubbing/fitment issues will be present with a mt et series radial on there
Old Oct 20, 2008 | 03:23 PM
nsxtasy's Avatar
H-T Order of Merit
For your street tires, you definitely want to go with 195/55-15 or 205/50-15 tires, which can be mounted on 15x6, 15x6.5, or 15x7 wheels. There are a lot of inexpensive, used sets of 15x6 GS-R wheels out there that should fit.
If you're getting a separate pair of wheels/tires to use at the dragstrip, I don't know much about those tires, other than that you can get BFG drag radials in 205/50-15 and they will fit on the same size wheels (6.0-7.0 inch widths). I wouldn't recommend them for street use, though, due mostly to rapid treadwear.
Old Oct 21, 2008 | 02:07 PM
the mickey thompsons im lookin at come in the 205/50r15 size. Im only gonna use these for the drag strip or occasionally street use. thanks for the post otherwise i coulda been s$%t out of luck
molsoncanadian
Dec 5, 2014 08:59 AM
FTNW
May 3, 2011 02:53 AM
TylerLorenz
Oct 6, 2009 04:17 PM
Mr.DXt
Feb 13, 2009 03:36 PM
Chronicsinners
Mar 19, 2006 06:01 PM
