Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Alternator Problems
Old Oct 18, 2008 | 12:21 PM
Stites's Avatar
Default Alternator Problems
I haven't been on HT in forever, couldn't remember my old login, so I am starting fresh.
I now have a 2003 Accord V6 (big change from the b18 95 civic
Anyways...
The battery light came on about two weeks ago. I drove it for another 2 days, and then replaced the alternator with one from pep boys. It worked great for about 4 days, then the battery light would come on, sometimes flash, sometimes not on, just randomly.
So after a few days of this I take it to Honda. They tell me my battery is gone, so they put a new one in. I pick up the car and after 10 minutes, the battery light is back on. AHH!
I take the car back and they run some tests and say the Alt is bad and I should replace it. This is where I am right now.
They say the alt could have gone bad because of the old battery. Does this seem right? They said it should be fine once I replace the alt.
Could anything else electrical cause this, or should I just replace the alt tomorrow and see what happen?
Thanks!
Old Oct 21, 2008 | 03:12 PM
Perfectionist's Avatar
Default Re: Alternator Problems (Stites)
I don't see how a battery would kill an alternator but still work well enough to start the engine and power accesories. If it were internally shorted, you should have noticed other problems. As for rebuilt alternators, I have had poor luck in the past. In my case it was the bearings went bad. Maybe your replacement suffered an electrical failure?
Anyways, make sure the wiring connectors are all clean and have no bent pins. Also, check the wire running from the alternator to the fuse panel (it supplies the battery with recharge current) and make sure it is not damaged and the connections are clean and tight.
Old Oct 27, 2008 | 03:56 PM
bracer's Avatar
I changed my alternator out at 105k only because I drive a long way to work and drive home in the wee small hours of the morning. The alternator was working just fine when I pulled it off. Honda Alternators are robust. How about asking Honda to run a check on the alternator and if they say it is bad, it probably is bad. If you want to buy my old alternator with 105k miles on it, I'll sell it to you for $70 bucks.
Old Oct 27, 2008 | 04:12 PM
someone else's Avatar
It Wasn't Me!
Default Re: Alternator Problems (bracer)
I have seen nothing but problems with aftermarket alternators on Hondas. Even on the old late 80's cars. Chances are it's a bum alternator.
Old Oct 29, 2008 | 02:28 PM
Yuen001's Avatar
Default Re: Alternator Problems (someone else)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone else &raquo;</TD></TR><TR><TD CLASS="quote">I have seen nothing but problems with aftermarket alternators on Hondas. Even on the old late 80's cars. Chances are it's a bum alternator. </TD></TR></TABLE>
i agree, i work at a shop and i've put in aftermarket alternators that don't even work out of the box
Old Oct 30, 2008 | 04:22 AM
BLKFLSH's Avatar
Take that alternator back to Pep-boys, and get an OEM alternator.
Old Oct 30, 2008 | 06:41 AM
Ross 2.0's Avatar
In a Junkyard near you.
I had one on a similar car. He claimed he bought it from Advance auto. But it was clearly a junkyard alternator. I sure hope he wasn't telling the truth.
But the "aftermarket" alternator was making the lights flash like my '68 Ford.
marklyzz
Mar 14, 2024 03:01 PM
Dj HeetazMalone
Classic Hondas
Jun 15, 2017 07:24 AM
Pr0ject93hb
Classic Hondas
10
Jul 22, 2008 09:33 PM
gascrazy
Sep 17, 2007 06:05 PM
Alexnaderkeith
Sep 10, 2003 08:32 AM
