1992 accord ex mt wont start
Old Oct 18, 2008 | 12:06 PM
ebrathole's Avatar
Default 1992 accord ex mt wont start
car wont start... replaced fuel injection relay, distributor, ignition switch, spark plugs, ignition coil checks with proper resistances, injector resistors check ok, has fuel coming to the fuel rail, seems to be under pressure, computer has power and ground at terminals, enginge coolant temperature is not shorted out, basically nothing seems wrong, but it wont start
Old Oct 18, 2008 | 03:52 PM
dtapia's Avatar
Default Re: 1992 accord ex mt wont start (ebrathole)
so does the car have spark ? has the icm been checked?
Old Oct 18, 2008 | 04:02 PM
P_Adams's Avatar
First, you'll have to determine what of the three main ingrediants you don't have.
1) Compression
2) Fuel
3) Ignition
You mention all the things you've replaced, but you haven't mentioned what you've checked to date.
You're going to need a second pair of eyes for this.....
1) Does the distributor turn while the engine cranks? (Checks for broken Cam / Timing Belt)
2) If the Distributor does turn, do you have spark? (connect a ignition wire to one of your old plugs and rest it against the valve cover - the spark should be white and quite apparent.
Start there and let us know what you found
P
auroradawnnnn
Jun 18, 2013 04:56 PM
samvilay
Oct 31, 2009 02:46 PM
curiousgpnoy
Oct 9, 2009 03:03 PM
dan89crxsi
Feb 10, 2007 02:44 PM
b20vtechatch
Mar 21, 2006 10:15 AM
