New clutch making noise
Hey guys,
I replaced the clutch pressure plate, disc, flywheel, throw out bearing yesterday on my 1989 Integra LS. Didn't adjust the cable and started the car so it made noise as if something was scratching or grinding. Adjusted the cable, got a lot better. But even in neutral it makes slight scratching noise, when I depress the clutch gets slightly louder. Car runs fine, changes gears just fine too.
What do you think is causing this noise and can it be fixed without taking the tranny out again?
g2tegsown
Jul 19, 2007 08:58 AM
