mobil 1 syn oil change
Old Jul 29, 2002 | 05:11 AM
Anderson's Avatar
Default mobil 1 syn oil change
just had my first oil change to mobil 1 syn for the first time.
for some reason my vtec doesn't kick in till after 6000rpm and it dosen't feel as aggressive as when i was using conv oil? but i was able to redline my car alot easier.
Old Jul 29, 2002 | 05:21 AM
Anderson's Avatar
Default Re: mobil 1 syn oil change (Anderson)
oh yeah FYI i used
5W30 mobil 1 syn
so why would i vtec higher?? and at not as aggressive VS. using conventional oil?
Old Jul 29, 2002 | 05:28 AM
Turtle's Avatar
temps are the same when comparing? you may want to check oil pressure.
Old Jul 29, 2002 | 05:35 AM
2001TypeR's Avatar
ummm i just got synthetic and im waiting to put it in but i dunno about this now, i really don't think that should happen, should it?
Old Jul 29, 2002 | 05:46 AM
Anderson's Avatar
Default Re: mobil 1 syn oil change (401-2001)
yup the temps are the same.
sorry dude. how do you check the oil pressure?
Old Jul 29, 2002 | 05:48 AM
Flux's Avatar
Make sure everything is on tight and nothing is leaking...
Old Jul 29, 2002 | 06:04 AM
Anderson's Avatar
Default Re: mobil 1 syn oil change (Flux)
yup very tight.
so that's why, i'm wondering whats up with da?
Old Jul 29, 2002 | 06:09 AM
DarthLuder's Avatar
New User
I just bought some Tri syn Mobil 5w-30 yesterday.
Old Jul 29, 2002 | 07:17 AM
Flux's Avatar
Default Re: mobil 1 syn oil change (ITR GURU)
What kind of useless post is this?
Old Jul 29, 2002 | 08:25 AM
2001TypeR's Avatar
Some body please get some results cause i don't wanna put my mobil 1 oil in if taht happens , but i really doubt it should happen, what do you think flux?
Old Jul 29, 2002 | 09:01 AM
Tweakmeister's Avatar
Default Re: mobil 1 syn oil change (2001TypeR)
Mobil 1 is fine....
is all of your oil in? did you check after the the ride?
RedLine is a better product, but Mobil is not bad at all >> it's better than 90% of the other oils out there.
Old Jul 29, 2002 | 09:19 AM
Flux's Avatar
There is something else going in here - it is not the Mobil 1 oil...
Old Jul 29, 2002 | 09:33 AM
Type-Rare#1248's Avatar
What kind of useless post was that?
Old Jul 29, 2002 | 10:01 AM
Chris N's Avatar
Default Re: mobil 1 syn oil change (Type-Rare#1248)
i picked up a bottle of Mobil One at the AutoZone yesterday... and put it back on the shelf! (That was also a useless, non helpful statement!)
I'm positive that changing oil has absolutely nothing to do with vtec engagement or anything else like that. Make sure the engine was warmed up, make sure all your nuts and bolts (and twig and berries) are on tight, and make sure all other variables are the same before you blame the new oil.
That said... Mobil One 5w-30 burns WAY too much.
Old Jul 29, 2002 | 10:09 AM
WOTTEG's Avatar
What weight of oil did you use before?
5w30 may be too thin. (I am weary of using it, bu tI live in TX)
I'll bet it's the weight change. . . . .
Old Jul 29, 2002 | 10:26 AM
SoCal ITR's Avatar
Yea, a LOT of ITR owners put Mobile 1 in, that is def. not the problem.
Edit: 5W30, 10W30, either of them is fine, it won't affect your car at all.
[Modified by SoCal ITR, 11:28 AM 7/29/2002]
Old Jul 29, 2002 | 11:59 AM
B2FiNiTY's Avatar
Default Re: mobil 1 syn oil change (SoCal ITR)
This is a very interesting problem. I wonder what it maybe? Have you checked your oil?
Old Aug 8, 2002 | 05:20 PM
2001TypeR's Avatar
Default Re: mobil 1 syn oil change (B2FiNiTY)
Got my oil change to mobil 1 synth also and no problems at all...
Old Aug 8, 2002 | 07:16 PM
jond's Avatar
What rpm did vtec kick in before?
I run mobil 1 5w30 and it kicks in for me right at 6,000 rpm.
Old Aug 11, 2002 | 12:51 AM
AccrdATK's Avatar
New User
Default Re: mobil 1 syn oil change (jond)
hmm, i changed to mobil 1 at 12,000 miles and have been using it ever since (33000 miles on car now) i noticed it burns alot ever since i put it in, and i dunt know if its me, but it does make a difference if your low on oil! so yah, so all in all, i think mobil 1 is fine
Old Aug 11, 2002 | 02:44 AM
01PYITR's Avatar
Default Re: mobil 1 syn oil change (JdMR-536)
... mmm.... I wonder..... Overfill?
Old Aug 11, 2002 | 07:11 AM
erottik-R's Avatar
I posted this before but I changed my oil to Mobil 1 syn. from conventional And I have found that I can drive 60-90 miles farther on a tank of gas. I know this because I take very long cross country trips (750 miles same route) and since the oil brand change I can skip the gas stations I always stop at. I’m not saying this newfound mileage was due to the new oil. Maybe something was adjusted. Maybe the gas stations moved closer but that is my experience.
Old Aug 11, 2002 | 07:27 AM
mugenracer's Avatar
Default Re: mobil 1 syn oil change (erottik-R)
thinner synthetic oil means les resistance in engine, and since the engines parts are able to move more freely , then the engien has to do less work and so mpg should rise a little, but 60-90 seems like a lot extra from just oil.
Old Aug 11, 2002 | 04:15 PM
Blue Liquid's Avatar
New User
Perhaps you just think your crossover is happening later than usual. Kinda like when I wash & wax my car it just feel faster than when it's dirty...
Old Aug 11, 2002 | 04:22 PM
dose's Avatar
could what hes hearing be his secondary butterflies
