OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto
Old Oct 17, 2008 | 06:05 PM
P_Adams's Avatar
Default OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto
Condition recurres after 5 / 20 cycles - 8 to 150 miles.
Ecm resets correctly (Clears codes)
Several techs / shops independently come back with same condition - ecm fails to supply ground for EGR circuit - they think ecm is trash (and yet it resets and works (for a while).
Done to date:
2nd ECM - same condition
reinstalled original ECM - same condition
replaced EGR solenoid - same condition
Any guidance would be appreciated
Thanks in advance
P.
Old Oct 18, 2008 | 09:17 PM
baller status's Avatar
Default Re: OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto (P_Adams)
Did you clean out both the intake and exhaust side of the EGR ports?
Old Oct 20, 2008 | 06:05 PM
P_Adams's Avatar
Default Re: OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto (baller status)
No, not yet. I've got all manner of people yelling ECM's, Lift sensors and EGR control solenoid but I'm not convinced yet.
The thing is, I'm exibiting some of the symptoms of the carbon build-up problem: a surge / chuggle (feels like one cylinder drops out under light load at / around 2000 rpm - right where the EGR starts working).
P
Old Oct 21, 2008 | 10:02 AM
Turbowa's Avatar
Clean out the EGR port in the head and the IM. You will need to take the intake mani off of the car to clean it right.
Old Oct 22, 2008 | 05:34 AM
kine462's Avatar
Default Re: OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto (Turbowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">No, not yet. I've got all manner of people yelling ECM's, Lift sensors and EGR control solenoid but I'm not convinced yet.
P</TD></TR></TABLE>
DUDE, I work at a dealer and see this problem all the time. We ussualy clean out the intake manifold and replace the egr valve with a new one. I belive they have a kit that comes with a new valve and several gaskets. You have to clean it out pretty well or the light will keep coming on.
Doug Winsor
Aug 26, 2015 12:40 PM
P_Adams
Oct 18, 2008 08:58 AM
Rev2 9K
Mar 1, 2008 03:26 PM
businessmanph
Mar 14, 2006 09:52 AM
businessmanph
Nov 23, 2005 06:16 PM
