cylinder pressure
Old Oct 17, 2008 | 02:56 AM
Ovrbst_T66's Avatar
Default cylinder pressure
Can being to conservitive on ignition timing raise egt's and cylinder pressures enough to lift the head and blow out a headgasket.
Old Oct 17, 2008 | 05:17 AM
NJIN BUILDR's Avatar
Default Re: cylinder pressure (Ovrbst_T66)
Retarded timing can raise egt's but shouldn't cause head gasket problems.Make sure your base timing is correct.
Old Oct 17, 2008 | 07:25 AM
HiProfile's Avatar
Default Re: cylinder pressure (NJIN BUILDR)
Retarding timing to an extreme degree will start to raise EGT's, but never peak cylinder pressures. 'Perfect timing' will put peak pressure at 14* past TDC. Less timing will put it further past TDC, meaning a lower overall pressure in the cylinders.
lsdc4
Apr 20, 2009 07:55 AM
Cyphear
Jun 9, 2007 09:10 AM
DonF
32
Jan 8, 2007 11:55 AM
94dxt
Apr 12, 2003 04:40 PM
